How to: Cleaning the MAF
Old Jul 17, 2009 | 07:26 AM
Nos Know Equal's Avatar
Nos Know Equal
Hey the pics aren't up on this anymore
Old Jul 17, 2009 | 07:36 AM
DavesZ#3's Avatar
DavesZ#3
Did you even read the post before yours?
Old Oct 28, 2009 | 03:44 PM
Jit13's Avatar
Jit13
I found pic's here
http://www.mygfrenzy.com/forum/showthread.php?t=7890
Old Oct 29, 2009 | 12:54 PM
gman08's Avatar
gman08
Great Tip!
Old Oct 29, 2009 | 01:06 PM
03aeroZ's Avatar
03aeroZ
Nice...I was waiting on this...know what I will doing this weekend. Anything besides decreased mileage and rough idle that a dirty MAF would cause?
Old Nov 4, 2009 | 03:28 AM
NISMOFO's Avatar
NISMOFO
My car is due for some maintenance, this is on my list of things to do. Thanks for the help.
Old Nov 8, 2009 | 09:38 AM
LVZ053's Avatar
LVZ053
Just cleaned mine yesterday, I was getting 16 mpg according to the indicator before and now I am getting around 22mpg. The true test will be the miles I get out of my tank because the MPG indicator in the car may not be too accurate.
So far happy with the results. I have a K&N high flow air filter also.
Old Nov 9, 2009 | 04:38 PM
Jit13's Avatar
Jit13
wow your lucky i get 17.1 mpg and avg 19
So far I have done this
-Cleaned the MAF
-Cleaned the JWT Pop Charger
-Cleaned the throttle body
-Replaced the Spark Plugs
-Replaced the Belts
Any idea what else I can do ? I have an 03 Track with just intake and exhaust (motordyne dual shockwave)
I use Amsoil oil and filter + chevron 92 octane gas all the time
Old Nov 9, 2009 | 05:13 PM
BakaN20's Avatar
BakaN20
-Cleaned the MAF
-Replaced the Belts
You try resetting the ecu? Have it relearn and stuff. Nothing wrong with your o2 sensors also right? Just some ideas. Good luck.
Old Nov 9, 2009 | 06:40 PM
Jit13's Avatar
Jit13
To reset the ecu I just disconnect the battery right ?
The car runs fine no problems whatsoever !
Old Nov 10, 2009 | 04:57 AM
350Zenophile's Avatar
350Zenophile
A clean popcharger will actually decrease gas mileage since the car has to increase fuel to match the denser air charge (in order to make more power).
The biggest determiner of your gas mileage is your right foot, then driving conditions; traffic, short trips, etc.
Car parts are lower on the list, but here are a few things that come to mind if you are noticing a big decrease in fuel efficiency:
- Did you recently add fat sticky performance tires? They will get worse MPG than standard touring/all-season tires.
- Tire air pressure
- Load. Install 200lbs of ICE lately?
- Fouled O2 sensors. Even if they aren't tripping a CEL, they may be telling the ECU to run richer than necessary.
Old Nov 11, 2009 | 12:36 AM
Jit13's Avatar
Jit13
Hi thanks for your help but I think it may be my driving style ! But I have reset the ecu and I noticed it idles a lot better and does not shake at all so it must of helped..
Old Nov 11, 2009 | 08:14 AM
BakaN20's Avatar
BakaN20
After you reset your ecu, drive like a granny for awhile. Did you reset the battery or do the whole ecu reset procedure? Also, like the butterfly position reset and all those other resets. Does anyone know if disconnecting the battery resets all of that also.
Sorry going ot.
Old Nov 11, 2009 | 12:19 PM
Jit13's Avatar
Jit13
i just did the whole ecu reset (Did not disconnect the battery)
Old Aug 31, 2011 | 02:13 PM
MikeBit's Avatar
MikeBit
I seriously wish there were pics for this. I talked to my mechanic about cleaning the MAF sensor and he immediately went "don't even think about touching it. It's so sensitive you can mess it up." It pretty much deterred me from trying it. I want to clean my MAF & throttle body but worried that I'll end up messing something up + not having the resets work. I've read threads where people would do these things, do all the necessary resets/relearns, and the idle stays terrible. I wish I was mechanically savvy.
Old Oct 24, 2011 | 08:07 PM
Bmurray350z's Avatar
Bmurray350z
I'm thinking I need to do this. My car runs fine for 2 minutes, then I run it WOT and it rises up around 5k very fast and then like loses power and jerks back and forth then continues to rise... Sound like the MAF?? any help would be MUCH appreciated, this is freaking me out.
btw sorry to bump this old a$$ thread.
Old Mar 22, 2012 | 11:32 AM
briin79's Avatar
briin79
Here is how to clean the popcharger http://www.jimwolftechnology.com/wol...ANING-INST.PDF
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
