How to install CJM Stage 2 fuel system
Old Mar 14, 2016 | 07:37 AM
Staisman's Avatar
Staisman
Default How to install CJM Stage 2 fuel system
This past weekend I was doing CJM Stage 2 upgarde installation and since the kit comes with no instructions whatsoever I looked for help online with no luck. So I decided to make this DIY guide.
Since I already had Stage 0 installed you will not find info about pump installation or return line in here.
See this for pump install (http://host.cj-motorsports.com/pdf/3...uel%20Pump.pdf)
1. Preparation
Start the job on Saturday to have Sunday in case you can't finish it the same day. It took me over 8 hours to do it.
Rise the car on the 4 stands and remove front and rear crossmembers under the car. Then remove intake manifold and fuel rails.
2. Installation
In the picture below:
#1 is your P-Regulator -> Front side Fuel rails line
#2 Fuel rails
#3 Two short lines that going from a back of your fuel rails to the Y adapter
#4 Y adapter
#5 Braided line (wrapped in insulation on the pic) that goes from Y adapter down to the hard pipe.
There is one more line that is not on the picture that goes from the hard line to the fuel pump at the gas tank side.
Remove and discard fuel rails with dampeners and metal bracket, we not gonna use any of it. Next, remove the old hardpipe. This is a hardest part. First unclip the line from plastic brackets, then it's a lot of twisting and pulling. You don't have to remove the fuel tank unless you want to preserve original fuel line. I literally destroyed my stock line by twisting and bending it under the car trying to get it out. After the stock line removed, you can start by putting a new hard pipe into the place.
This is how the line looks under the car.
Tank side.
Front of the car.
Middle.
After you done installing the pipe you can now drop the line from a pump assembly down to the hardpipe. There is single connector comes with a kit and has cut through nut in it. You will use it to connect this line and a pump assembly.
Connector with cut through nut on the pump assembly.
Now you can do your rails. You have to install your injectors into the rails first. Then you can install the rails. Now connect #1 line to the front side of your injectors. I put the line a long the sides of the rails and cross them on front of the engine block. See pic below:
Front side of the engine. Left line to the right rails and a right line to the left rail.
Connect another side with a T to your pressure regulator.
Now connect Y adapter #4 on to straight connector on the braided line. Drop the line down the firewall and connect two short lines #3 to the Y adapter. Now connect them to the back of your rails.
Go under your car and connect braided line #5 with 45 degree connector to the hard pipe.
Go over and tighten all the connections. Those that connect to the hard pipe tight very hard because they will leak.
Put you intake manifold back, connect two evac line together, reconnect all the connectors that you disconnected. Check everything one more time and now you can start your car. While it's running go over and check every connection on the fuel lines, because something will leak. Put your crossmembers back and drop the car.
Let me know if something is confusing and I will fix it.
P.S. This post is for informative purposes only. You do all the work at your own risk. Happy modding.
Old Mar 14, 2016 | 08:59 AM
phunk2's Avatar
phunk2
Thank you for sharing this!
Old Mar 14, 2016 | 06:45 PM
rustyschopshop's Avatar
rustyschopshop
great write up!!
Old Jul 14, 2016 | 08:19 PM
TT03Z's Avatar
TT03Z
Awesome write up and info man! I will be doing this same install in the near future and will be using this as a guide so thank you!
Old Jul 14, 2016 | 08:21 PM
TT03Z's Avatar
TT03Z
Also if you don't mind me asking where did you get the kit from and how much did you pay for it? Did you also get the fuel dampers?
Old Jul 15, 2016 | 10:43 AM
phunk2's Avatar
phunk2
The CJM rails are not available without dampers since they were updated 3-4 years ago
Old Jul 15, 2016 | 12:18 PM
TT03Z's Avatar
TT03Z
Ok I was curious because conceptZ lists it as an option when you order the stage 1 and 2 kits. I thinks it's like a $50 option. But I will definitely remember that.
Old Jul 15, 2016 | 12:45 PM
phunk2's Avatar
phunk2
If you ordered the kit without the dampers, they would still be required, just not included. You would have to spend $50 at the Nissan dealer to get them in order to plug the damper holes in the rails. So the option was just eliminated for the sake of simplification.
Old Jul 15, 2016 | 02:29 PM
Staisman's Avatar
Staisman
This is a kit from cj motorsports (CJM), call them and Charles will get you everything you need for your HP target. Very nice guy
Old Feb 18, 2017 | 01:49 AM
BluestreamDE's Avatar
BluestreamDE
sub'd for install reference.
Old Dec 5, 2017 | 09:05 PM
terrasmak's Avatar
Looking at this install, I think I need rails before I do it
35reilly
Mar 25, 2017 12:51 PM
djtimodj
May 15, 2016 12:58 PM
irishsig
Suspension
Apr 26, 2016 10:46 AM
BlueSpeakers
Feb 27, 2016 04:36 PM
