Hr mounts on de chassis
ok so my mounts on my g35 are f#cked. literally engine lifts up on acceleration. i have a full hr setup sitting on the side for another project, basically i’m just asking if the urethane part of the mount(just the black with threads on each side.) will bolt up to the metal part of the DE mount, and then into DE subframe.
z1 aftermarket mounts come in on sunday but i’m tryna make the drift event this saturday. so just a quick fix that will work
would call z1 to verify
one thing i would be concerned with is changing the level of the engine putting the driveshaft in a bind. Am pretty sure they would bolt it but putting that much abuse on drive line would want to make sure tolerances are correct.
ok thanks bro, i actually just got my friend to loan me his mount from his vq that’s out of his z at the moment. such a b!tch to change, even with megan headers.
I did mine while i was changing my engine so it made it alot easier.
Unmounting the a/c compressor will probably make it really easy. My passenger side now would be cake with all my deletes. Almost completely open.
