Engine light, vdc and slip on, throwing no code,
Old Jan 16, 2022 | 03:19 PM
travlee's Avatar
travlee
Master
Please don't double post
Old Jul 31, 2022 | 08:03 PM
Trexx139's Avatar
Trexx139
Default You have a bad Engine ground.
Hi I just went through this when I put my motor in my car 350Z 2005 I experienced the same issue it was because I had a bad engine compartment ground.
So look at your grounds on the engine there's one at the if you're looking at the engine the top left then righthen write below that halfway down we'll not halfway down but there's 2 grounds on your left 2 in the center and 1 all the way on the right side of the motor connected to the body and it's like it's not a wired kind of like a mesh cable.
travlee
Jan 16, 2022 03:14 PM
UCF350z
Oct 30, 2014 12:01 PM
