First off no update yet really... I ditched the overfenders I have for the front and rear and have some new ones being made fresh out of mold. Reason for this decision was due to available for replacement parts. Old overs were from NZ and would be hard to get spares so hooked up with a guy in the states.. So should have those soon.
Here is a little tease of the fronts... Still have to get a alignment and get my fronts sitting at -4.5 camber.. Then I will add a spacer to finish her off... This just give you a idea.. Current front specs are 18x9.5 -22
If you look at my signature it clearly states how I feel about spacers.. Well since I built these wheels to go with my other fenders I will definitely have to get some spacers for these fenders, which I hate. I will eventually rebuild them so I wont have to run spacers but I guess I better remove my sig for now... lol
So pretty much the story is, I used my new Coolant refill system.. Everything looked good.. The next morning I see a little coolant puddle.. Looked at all fittings no leaks.. Than BAM!! found the leak at the rear of the head gasket.
So I am like how the hell did that happen.. So me being so trust worthy, I never questioned the gaskets that were given to me when I got the long block. Turns out my heads 806 have a notch in them and the MLS gaskets I have can some times (most of the time) cause a leak due to the notch in the heads.. With that being said we are suppose to use the graphite gaskets instead of the MLS ones I had.. So I had to change them..
Not fun but no worries easy fix...
So now head gaskets are changed and ready to wrap her up.. cross fingers soon.. lol
