Engine Swaps For all your engine swap experiences, ideas, questions, & more..
VK56 Swap
Old Aug 25, 2017 | 08:05 PM
NissanJon's Avatar
NissanJon
Default VK56 Swap
Does anyone have a comprehensive list of necessary parts and integration blocks for the 350z VK56 swap? Obviously, employing the manual RE5 requires an adapter plate, also needs a solution for the VK CAS location on the trans bell housing if switching to a manual. New engine mounts, new trans mounts if you push the engine back to the fire wall, what else? Factory Titan harness? Haltech? What does it take to get a VQ powered Z into a VK powered Z?
Old Aug 25, 2017 | 08:29 PM
NissanJon's Avatar
NissanJon
I'm starting a VK56 swap myself and would like to not go into this completely blind. Everyone knows about the swap, and some of you have actually done it, but no one seems to know exactly how its done, even those who've done it.
Ill be logging all of my information to write a comprehensive 'How-to' in the future, after I get the project near completed, but I could certainly use some insight.
Old Aug 26, 2017 | 06:06 PM
dcains's Avatar
dcains
Why don't you search this site? There is a thread currently open discussing this topic.
Old Aug 26, 2017 | 06:22 PM
NissanJon's Avatar
NissanJon
I have searched the site and found nothing of any substance. Which thread are you referring to? Most threads are filled with people giving each other high fives.
Old Aug 26, 2017 | 09:55 PM
dcains's Avatar
dcains
This thread took me 2 seconds to find. Lots of good info:
https://my350z.com/forum/g35-g37/611...vk56-swap.html
Old Aug 27, 2017 | 02:45 PM
quickdiversion's Avatar
quickdiversion
haha thanks for linking my thread....
Old Aug 29, 2017 | 06:58 AM
iideadeyeii's Avatar
iideadeyeii
WHYYYY
LS and call it a day. Cheaper/better
Old Aug 29, 2017 | 07:30 AM
travlee's Avatar
travlee
Master
Originally Posted by iideadeyeii
WHYYYY
unless you go big
http://www.karlperformanceparts.com/...SABEgJAsfD_BwE
Old Aug 29, 2017 | 07:54 AM
iideadeyeii
Originally Posted by travlee
Can't a stock ls1 handle FI at 500whp easily?
Can't anyone do a custom rear-mount turbo for an ls swap for under 2k maybe 3k with an expensive turbo
That engine is just so overpriced.
Old Aug 29, 2017 | 08:03 AM
travlee's Avatar
travlee
Master
yeah it is, and unless you fix the valve guide issue you have to worry about trashing the motor.
if i were me, i would do ls2/ls3.. little stronger, and yes there is a rear mount turbo
Old Aug 29, 2017 | 08:43 AM
quickdiversion
WHYYYY
Cool story bro, show me your ls swap into a z/g platform. Love to see how easy your stand alone system was.
Old Aug 29, 2017 | 08:58 AM
travlee's Avatar
travlee
Master
oh you mean like this? this is my buddies car, we did all the manual labor and then it went to the shop for wiring harness and tune. cant remember the final total, will text him
Old Aug 29, 2017 | 09:17 AM
quickdiversion
Exactly. You didnt do the wiring and by the lopks pf the motor location, you destroyed the eright distribution just to put the motor in.
I never said it was bad.
I talking getting it running yourself, the mechanical work is easy.
Old Aug 29, 2017 | 09:20 AM
travlee's Avatar
travlee
Master
the sikky did came with the wiring, but one part confused us so we didnt mess with it, but it piggy backed both ecu's
and we didnt destroy anything, the ls motor sits lower and further back... that is how every ls swap is
Old Aug 29, 2017 | 09:25 AM
travlee's Avatar
travlee
Master
all we were saying is that the ls swap has been done numerous times and most of the kinks have been worked out..
i give you props on your build, read the thread from time to time
Old Aug 29, 2017 | 09:36 AM
iideadeyeii
Quickdiversion has a personal vendetta against any motor swap that is easier than his tedious and "steady-paced" vq56 swap.
He'll show those ls swapped z's what 265whp and 325wtq is all about in about 3-4 more years
. . .And the fact that barely anyone cares for his build
Old Sep 4, 2017 | 10:53 AM
quickdiversion
Cute.
There is plenty interest in my build.
Yes my build is steady paced, I have a budget and I stuck stuck to it. When you work a lot and your married an engine swap is not always my priority.
Old Jun 13, 2021 | 10:48 PM
B.Frye91's Avatar
B.Frye91
BROSKIS! Quick Diversion finished his build! Check it out...
Wait till the end, his wife twerks on the hood whilst he does thy holy drift 🍩 's
Old Jun 14, 2021 | 03:24 PM
False1's Avatar
False1
https://youtu.be/VYJxKHZ9eRg
where’s it at!?
Old Jun 14, 2021 | 03:31 PM
quickdiversion
Northeastern NJ.
07920
