Engine Swaps For all your engine swap experiences, ideas, questions, & more..
2JZ swap not lining up
Old Dec 11, 2017 | 08:21 PM
rob2496's Avatar
rob2496
Default 2JZ swap not lining up
So I recently put the motor in the car thinking everything would be fine however the engine is just not lining up correctly as you can see from the picture it causes the transmission to go towards the passenger side rather than the middle and yes this is when I tighten up the mounts. The only thing I can think of is the engine mounting brackets were not made correctly. They are freed engineering mounting brackets, I also had to drill a bit bigger of a hole to get the holes to line up on the engine block correctly so I don't think it's far fetched that the brackets are angled wrong. Anything else you guys might think is causing this?
Old Dec 12, 2017 | 06:27 AM
CK_32's Avatar
CK_32
Have you emailed them and showed them this?
What's was their reply
Old Dec 31, 2017 | 08:05 AM
35reilly's Avatar
35reilly
I’m curious to know what’s up as well.
Old Dec 31, 2017 | 10:27 AM
travlee's Avatar
travlee
Master
Makes me wonder if mounts are side specific
Old Dec 31, 2017 | 11:41 AM
rob2496's Avatar
rob2496
Sorry for not updating this when I figured it out, to those who are wondering the mounts are side specific they are labeled left and right, right being passenger side and left being driver. The problem was the mounting points on the block. I have a vvti which has different mounting points on the block than other JZ blocks but the vvti block still has the holes tapped they’re just not used from the factory. When I took off the oem mounting brackets I simply put them back in the same spot but that’s incorrect if you have a vvti. This all only pertains to the exhaust side the intake side only has one mounting location. So if you have a vvti don’t use those mounting points use the other set that’s on the block.
Old Feb 17, 2018 | 07:27 AM
vinniePOOH's Avatar
vinniePOOH
Are you building this yourself like ChaseZ 2jz build or are you having a shop help you out??
Old Feb 18, 2018 | 10:36 PM
rob2496's Avatar
rob2496
I’m doing everything myself however not to the extent chaseZ is. He made is own mounts, exhaust and pretty much everything that requires a lot of fabrication. Unfortunately that is not in my skill set. I’ve bought all my mounts and then will be sending it off to a shop for intercooler piping and exhaust. Everything else has been done by me so far. If you’d like me to start a build thread let me know.
Old Sep 2, 2019 | 01:18 PM
vinniePOOH's Avatar
vinniePOOH
Any updates on this build? And did you ever take a after pix of the shift placement once you got mounts mounted correctly?? Keep up the good work!
Fairlady_z33
Jul 24, 2011 07:46 AM
seeya
Jun 7, 2011 08:32 PM
wasuber
North West
Aug 30, 2007 10:12 PM
paranormal
Apr 9, 2007 12:47 PM
Santacruzslick
Nov 10, 2006 03:23 PM
