Engine Swaps For all your engine swap experiences, ideas, questions, & more..
06 350Z LT5 swap
Old Mar 21, 2021 | 04:41 AM
TheDahctor's Avatar
TheDahctor
Default 06 350Z LT5 swap
I'm currently working on a project plan to drop an LT5 in my 350Z. Does anyone know if it's been done before? I saw where someone did an LT4 swap last year, so it's certainly possible. Having someone to lean on to fill in missing bits of information as I go would be very helpful.
Old Mar 21, 2021 | 07:16 AM
i8acobra's Avatar
i8acobra
Why? The LT5 was a great engine when it was introduced back in 1990, but now it's a heavy dinosaur. An LS1 or LS2 is lighter, more powerful and cheaper. Not to mention, there are several kits available that make as LS swap very easy.
Old Mar 21, 2021 | 09:42 AM
travlee's Avatar
travlee
Master
Lt5 is c7 zr1 motor, no?
Old Mar 21, 2021 | 11:05 AM
i8acobra's Avatar
i8acobra
GM's killing me with the stupid engine designation recycling. The old LT4 and LT5 aren't old enough to be forgotten. To me, an LT engine is a reverse coolant flow, iron block 5.7L GM engine. I'd be different if these engines were over 50 years old and there weren't really any left on the road.
Old Mar 21, 2021 | 11:55 AM
travlee's Avatar
travlee
Master
I have LT1, ZO6 has LT4 (Which BMCANN is putting in) and oo doing LT5. Brian is having issues with steering rack and what Trans to use last I read
Old Mar 21, 2021 | 12:13 PM
i8acobra's Avatar
i8acobra
Someone needs to smack GM in the back of the head.
Old May 13, 2021 | 01:57 PM
bmccann101's Avatar
bmccann101
the gen V engine is not the same as any of the previous old designs.
It is also direct injection.
OP, the amount of money you will spend to do this will be STAGGERING. Not to mention that the LT5 from the C8 is not set up to accept the same accessory drives or boost making as a normal front engine variant would be.
Long story short? a nice full crate ls3 hot cam comes w a warranty for 7200 bucks. the amount of accessories available for it are endless.. and making additional power is very very easy.
I am having to CAD and CNC my own oil pan as well, so factor in a 3-5k dollar oil pan to your build, the factory dry sump system is miserable to deal with in a swap.
Yes i will have a Kong ported cammed Gen V LT4....which no one has done in a z33 yet ( only l83s, maybe 1 with an LT1 and an auto trans) but ....with 100% DIY labor, i am still looking at 35- 40k spent. Its mind boggling. Its not worth it.
Is it a mistake? I think so, but its too late now. is what it is.
Old May 13, 2021 | 06:48 PM
i8acobra's Avatar
i8acobra
I know. My point was I think it's stupid that GM keeps recycling names. There's a whole lotta letters that can be used.
nichols
Engine Swaps
Aug 17, 2016 08:24 AM
Shahar Siboni
Aug 19, 2014 06:35 AM
Kung Fu Sifu
Oct 7, 2009 01:20 AM
BlackenedZ
Jan 28, 2008 04:53 PM
kernel
Aug 11, 2003 01:37 PM
