BRAILLE B2015 Light Weight Battery (Only 15lb!!!!)
EDO Performance
EDO Performance
$159.99 Shipped!!!
Also Available w/ Carbon Wrap $239.99 Shipped!!!
Model Name: B2015
Recommended Use: Winning Races!
Use this battery to get that last tenth of a second from your times.
Difficult and small engine location needs.
Can be used in pairs for custom application.
Competition and lightweight daily use in small displacement engines.
Excellent starting and running battery.
Not Recommended For:
Extreme Cold Climates
Extreme Audio Applications
Ultra High Compression Motors Running Aftermarket Ignitions w/o Alternators.
Specifications:
Casing: Polymer Plastic
Weight: 15 lbs
Length: 6.8
Width: 3.4
Height: 6.1
Pulse Cranking Amps: 1067
Cranking Amps: 574
Cold Cranking Amps: 425
Amp Hour Rating: 21
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
Model Name: B2015
Specifications:
Weight: 15 lbs
Length: 6.8
Width: 3.4
Height: 6.1
Cranking Amps: 574
Amp Hour Rating: 21
