Engine Intakes, Exhausts, Clutches, Turbos, etc...
**NEW** Agency Power Radiators!!
Old Jun 27, 2008 | 01:10 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Default **NEW** Agency Power Radiators!!
In stock now!! Just in time for beating the summer heat. Especially if you are here in AZ where it's 114 degrees.
For any vehicle, improved cooling is an issue that may be overlooked. When engine temperatures are high, the efficiency of your motor goes down. By providing better cooling capacity, you can maximize your engines performance. Increasing the radiator core dimensions and improving upon the flow design, Agency Power has developed these performance radiators kits. Whether your car is turbocharged or normally aspirated, an upgraded aluminum radiator will give you more performance on and off the track.
The all aluminum radiator features a high pressure radiator cap, aluminum construction, and mounting tabs for a direct OEM replacement. The factory fans and radiator hoses will fit with no modification. This kit is very easy to install and should only take about 1 hour. The core dimensions for this aluminum radiator are 29.55” x 19.30” x 2.53”. That is almost 25% bigger then the stock unit. In addition to having a larger cooling capacity, the aluminum radiators are much more durable then stock. The factory plastic end tanks can crack under extreme heat and pressure. Under racing conditions, your water temperatures can near boiling points. As tested under the intense Arizona heat conditions, the aluminum end tanks and larger core size help keep the temperature down by at least 15F degrees.
In addition to the aluminum radiator, Agency Power recommends upgrading to our silicone radiator hose kit and putting a coolant additive in with your fluids to help keep temperatures down. Radiators include 1.1bar radiator cap with Agency Power logo. This fits all Nissan 350Z vehicles from 2003 and up.
As always PM PM PM PM PM Me for best pricing!! I can beat anyone's price on all Agency Power products!!!
Old Jul 1, 2008 | 09:43 AM
Vivid Racing
Vivid Racing
Oh look, we have hoses to go with them. Package deal anyone?
https://my350z.com/forum/showthread....67#post5979467
Old Jul 7, 2008 | 10:17 AM
Vivid Racing
Vivid Racing
To the top!
Old Jul 11, 2008 | 09:38 AM
Vivid Racing
Vivid Racing
Special price $350 shipped!! 10 in stock!!
Old Jul 17, 2008 | 08:13 AM
Vivid Racing
Vivid Racing
If you are thinking Mishimoto or ebay...don't. These are Koyo and up quality.
Old Jul 21, 2008 | 02:55 PM
Vivid Racing
Vivid Racing
Bumped
Old Aug 6, 2008 | 12:50 PM
alverez954's Avatar
alverez954
interested. will it work with a mt 03 g35 coupe?...pm best price shipped to 33314, and also send separate price with hoses included. thx!
sales@czp
Sep 23, 2019 03:30 PM
SharX59
Sep 30, 2015 10:54 AM
codek
Sep 28, 2015 03:03 AM
