Engine Intakes, Exhausts, Clutches, Turbos, etc...
Haltech PnP EMS In Stock
Old Jul 15, 2008 | 07:10 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Default Haltech PnP EMS In Stock
Some Key Points for the Platinum PnP EMS:
• End User Tunable (not locked like some EMS on the market)
• Sequential Fuel and Ignition Control (32x32)
• Cylinder Trim Tables for each injector and ignition coil (8x8)
• Coolant and Air Temp Correction for fuel and ignition
• Complete Intake and Exhaust Cam Control (03-05’ Intake Cam control only) (24x24)
• Configurable Load and RPM points for all tuning tables
• Tuning via MAF, TPS, or MAP
• Fuel tuning by Volumetric Efficiency (VE) or Injection Time (MS)
• Injector drivers operate both Saturated and Peak & Hold injectors
• Map Trace
• Knock Detection
• Overboost Protection
• Open/Closed Loop Boost Control
• Dual Closed Loop 02 Control
• Onboard Data Logging
• USB Communication (no outdated Serial cable required)
• New Windows Tuning Software, ‘Haltech ECU Manager’
• 32Bit Microprocessor, 55MHz
• Plug and Play Loom
• Auxiliary two-step rev limiter
• Nitrous and Meth Injection Control
• Knock Control (coming soon in a free software update)
In your Platinum Series PnP EMS package you will receive the following:
Haltech Platinum Series EMS with onboard MAP sensor and onboard data logging
Plug and Play Harness
USB connection cable
Software and User Manual on CD
Retail $2299
Purchase Here
Old Sep 5, 2008 | 06:44 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Bump, check out the https://my350z.com/forum/forced-indu...romotions.html
Old Sep 10, 2008 | 07:40 PM
wannabuy350z's Avatar
wannabuy350z
hey Hal please PM me a price with boost controller. 92124 sep promo
Old Sep 11, 2008 | 06:04 AM
Dynosty's Avatar
Dynosty
^ PM Sent
Old Oct 22, 2008 | 08:16 AM
Dynosty's Avatar
Dynosty
Bump
