Engine Intakes, Exhausts, Clutches, Turbos, etc...
COSWORTH Short Block Clearance Sales !!
Old Feb 20, 2009 | 07:48 PM
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Default COSWORTH Short Block Clearance Sales !!
Cosworth Short Block (3.5L / 11:1 Compression Ratio) *** PM For Special Pricing ***
Limited Time Offer, expires 2-27-09
The Cosworth VQ35DE high performance short block is the perfect foundation for your high performance application. Each High Performance Short Block is hand assembled by one of Cosworth's skilled engine builders to exact specifications utilizing all new components and is available in either high compression 11:1 or low compression 8.8:1 for turbo or supercharged applications. To ensure smooth operation throughout the entire RPM range, each rotating assembly is carefully balanced, an essential requirement for high performance VQ35s. Additionally, comprehensive build sheet listing all critical dimensions is included. Use with our CNC ported Big Valve Cylinder Heads for maximum reliable performance.
Includes the following:
Cosworth Forged H-beam Connecting Rods
Cosworth Forged Pistons and rings
Cosworth Tri-metal bearings
Balanced to within .5 gram
Complete blue-print assembly
Ring gap set
Bearing clearance set
Deck height set
Connecting Rod side clearance set
Crankshaft end float set
Specification
Cosworth Forged Pistons (95.5mm)
Cosworth Forged H Beam Connecting Rods
New Nissan Forged Crankshaft (81.4mm)
Cosworth High performance Rod and Main Bearings
Cosworth High Performance Main Bearing studs
New Nissan VQ35 Alloy Block
Complete balancing of rotating assembly
Old Feb 20, 2009 | 07:54 PM
carfi179's Avatar
carfi179
Just Curious, pls. PM Me price for Cosworth Low comp.
Old Feb 22, 2009 | 03:50 PM
r0csfinest's Avatar
r0csfinest
PM price for a low comp engine for TT Z shipped to 20866 thanks
Old Feb 22, 2009 | 04:11 PM
SuperBlack350z's Avatar
SuperBlack350z
pm me please
Old Feb 22, 2009 | 04:44 PM
Bigchef66's Avatar
Bigchef66
low comp to 33312
regards
Old Feb 22, 2009 | 07:04 PM
deyj28's Avatar
deyj28
low comp to 53405
Old Feb 22, 2009 | 07:12 PM
DracoLancet04Z's Avatar
DracoLancet04Z
low comp to 76203 please
Old Feb 23, 2009 | 05:52 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I think this is gonna be out of my range, but lets see. Low Comp to 29579 please.
Old Feb 23, 2009 | 06:38 AM
captj3's Avatar
captj3
Low comp to 33437
Old Feb 23, 2009 | 07:56 AM
Asian Invasian's Avatar
Asian Invasian
low comp to 80525
Old Feb 23, 2009 | 07:58 AM
06Glover's Avatar
06Glover
pm me low comp to 85719
Thanks
Old Feb 23, 2009 | 09:27 AM
psychoballistic's Avatar
psychoballistic
low comp to 12533 please... thanks
Old Feb 23, 2009 | 05:45 PM
RavSpec's Avatar
RavSpec
PM'd, Thank you.
Old Feb 23, 2009 | 05:55 PM
forced_04's Avatar
forced_04
low comp to 94596.......
Old Feb 24, 2009 | 12:28 PM
RavSpec's Avatar
RavSpec
PM, but now only Hi comp 11:1 available, sale ends 2/27/09!
Old Feb 24, 2009 | 12:29 PM
longvan's Avatar
longvan
price shipped to vancouver b.c. for high comp
Old Feb 24, 2009 | 12:48 PM
RavSpec's Avatar
RavSpec
I'll pm you now, Thank you.
Depravity
Oct 1, 2015 04:49 PM
