Koyo / Mizu / Mishimoto Radiators || Hoses, Fans, Cooling Plates now at Statik!
Vendor - Former Vendor
*FREE SHIPPING*
*FREE SQUASH AIR FRESHENER WITH ORDERS OVER $100*
**WE PRICE MATCH ANY ADVERTISED PRICE**
V2577 36mm Core - $350 Shipped (within the 48 states)
R2577 54mm Core - $420 Shipped (within the 48 states)
*Note Koyo Radiators will only work on manual transmission cars.
Radiator:
Spec:
Core Size: 400mm x 715mm
Rows: 2
Inlet: 35mm
Outlet: 35mm
Core Thickness: 36mm
Tank Wall Thickness: 2mm
Fill Neck: 32mm
Purchase Includes: Mishimoto Radiator, Mishimoto Radiator Cap, 1 Year Warranty
$240 Shipped (within the 48 states)
Hoses
Spec:
Interior Material: Heat-Resistant Embedded Fibers
Exterior Material: Silicone
Max Temperature: 330 F
Colors Available
Black/Blue/Red
$85 Shipped (within the 48 states)
Fan Shrouds:
Includes:
Aluminum Shroud
(2) 12" Slim Electric Fans
Overall Size:
Height - 18.7"
Length - 28.5"
Width - 2.5" (including fans)
Mounting Hardware:
(8) M6X20 Screws
(2) M6X16 Screws
(8) M6 Nuts
(10) M6 Plain Cushions
(10) M6 Elastic Cushions
*Fans come pre-assembled with fans mounted
$185 Shipped (within the 48 states)
350z Aluminum Radiator, Manual 2003-2006
Item #: R-350Z-03
The Mizu performance aluminum radiator is the perfect upgrade to your stock radiator. Made from the highest grade of aluminum, all Mizu aluminum radiators are hand-welded and hand-made to create a perfect radiator with a direct OEM fitment without any cutting or modification needed. All Mizu radiators are designed and engineered to maximize cooling efficiency by increasing the radiator core's thickness, fin density and using 3 radiator cooling rows as opposed to 1. These advancements in cooling technology will protect your car from overheating under the harshest conditions. All Mizu radiators come with a high pressure 1.3 bar Mizu radiator cap and an unparallel lifetime warranty.
Item #: H-350Z-03BK
Mizu Silicone hose kits are made by combining three layers of high grade silicone and heat-resistant embedded fibers eliminating the likelihood of cracking and tearing of your hose. Mizu Silicone hoses are engineered to provide increased heat reduction and pressure resistance. Mizu Silicone hoses are designed and engineered for a direct OEM fit no modification needed. Mizu Silicone hoses are backed by Mizu's unparallel lifetime warranty.
PM for Intro Pricing!
Local pick up is availlable!..PM for Picked up Prices!!
pms replied...
Website is up with a complete brand list! Check it out and lemme know how I can hook you up = )
www.statikperformance.com
pms replied..
Be sure to check out
New Overstock/Clearance section coming soon!!
