Super Deal on Mishimoto Radiators
For a limited time you can double up the offers on Mishimoto Performance Radiators, in addition to the MishiRad coupon code (Valid online for $30 off) you can now add a set of Z1 Motorsports silicone coolant hoses for only $69. This hose set normally sells for $98 by itself, order a Mishimoto Radiator from us and get the hoses at an incredible price.
The Mishimoto performance aluminum radiator for the Nissan 350Z is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. Whether you drive your vehicle daily or take it for track runs. The Mishimoto aluminum Nissan 350Z radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required, the ideal upgrade to the stock Nissan 350Z radiator. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap.
Z1 Motorsports silicone coolant hose set for the 2003-2006 350Z or G35.
This 4 ply high quality silicone hose has been custom formed for perfect fitment on the VQ35DE.
These are last radiator hoses you will ever need. Unlike conventional stock rubber hoses that deteriorate over time, dry rot, and ultimately crack this silicone hose will stay soft and never degrade.
Z1 Motorsports offers a full line of silicone hoses for the 350Z and G35 that will be the last hoses you will ever have to purchase. They will outlast the car and they cost less than new OEM replacements! There's no reason to consider anything else.
Available in
BLACK
BLUE
RED
Cliffs:
Order A Mishimoto Radiator from Z1, add Z1 Coolant hoses to the order from the drop down menu, enter coupon code MishiRad at checkout to discount the radiator further at checkout. Save $$$$ and stay cool all summer.
- Overall Size: 29.7" x 21" x 4.45"
- Core Size: 15.75" x 28.15"
- Rows: 2
- Inlet: 1.4"
- Outlet: 1.4"
- Core Thickness: 1.42"
- Tank Wall Thickness: .08"
- Fill Neck: 1.25"
- Drain Plug Thread Size: (M16) .06"
- Drain Plug Thread Length: .047"
Available in
BLACK
BLUE
RED
Cliffs:
