Engine Intakes, Exhausts, Clutches, Turbos, etc...
Are you boosted? Let us help you make it better!
Old Oct 19, 2010 | 10:51 AM
S&R Performance's Avatar
S&R Performance
Vendor - Former Vendor
Default Are you boosted? Let us help you make it better!
We build more Boosted Z and G cars than anyone in the region. We've worked out the good from the bad, the weak from the beast! We can help you make your setup even better! We work with some of the very best manufacturers around for boost control, wastegates and Blow Off Valves. Check out these great parts that we have available to optimize your boosted setup!
Turbosmart is one of the premiere manufacturers for everything turbo! We use their wastegates, boost controllers and blow off valves all of the time! We love their entire line up! They have some great edges over the competition, take some time to check them out, you won't regret it!
Turbosmart Comp-Gate 40 External Wastegate:
Turbosmart’s brand new 40mm external wastegate was designed to fit into tight engine bays while still offering superior flow and heat handling capabilities. The revolutionary new actuator housing is 25% smaller than our current range and allows for easy spring changes and gives the ability to index the cap orientation in 12 different positions.
Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.75” outside diameter pipe.
Kit Includes:
* 7PSI Spring (installed)
* Inlet and outlet Weld Flanges
* Inlet and outlet V-Band clamps
* Valve seat, 2 x 1/16th blanking plugs
* 2 x 1/16th Vacuum nipples
* Locking Ring removal tool.
YouTube - Comp-Gate40 - The Smartest Wastegate in the World
$314.00 SHIPPED
Turbosmart 38mm Ultragate:
The 38mm external wastegate is small and light weight. The Ultra-Gate38 provides high-end features and build quality at an entry-level price. The 38mm Ultra Gate is suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.50” outside diameter pipe.
Kit Includes:
* 7 psi spring (fitted)
* Valve seat
* 2 x stainless steel gaskets
* mounting bolts
* 2 x 1/8 NPT vacuum fittings.
This is a very high quality wastegate. We've used these for years on all kinds of turbo kits. EVO, DSM, Nissan, Subaru and more.
$269.00 SHIPPED
Let's step it up to a blow off valve for the big boys!
The largest and the highest-flowing BOV in the Turbosmart range features an oversized inlet port and a quick-release V-Band clamp. Provides greater performance through faster turbo spool-up from idle and reduced turbo lag between gears.
Ideal for large capacity turbocharger systems and high horsepower engines. Great for circuit and drag vehicles and trucks
Kit Includes:
* Quick-release V-Band Clamp
* Aluminium Weld Flange
* Swivel Nipple
What's the bottom line? This is a Blow Off Valve for real performance. Serious performer for serious builders.
$269.00 SHIPPED
E-Boost Street Kit
Racing technology for the street
E-Boost STREET is an electronic boost controller aimed at the street performance market. It features many boost control capabilities found on its big brother – the e-Boost2, continuing the e-Boost tradition of providing class-leading boost control, value for money and no nonsense features.
New features include 40psi max boost operating pressure and an auxillary output.
2 Boost Settings: easily selected via the “turn-and-push” button. An external switch can also be used to change between boost groups if required.
Boost Correction Factor: eliminates boost drop off at high RPM.
3 Segment Display: with adjustable brightness can be configured for PSI, KPa, or BAR and will flash when warning of over boost shutdown or rev limit, allowing the unit to be used as a boost gauge, tachometer, or a shift light.
Dimensions: W:80mm H: 25mm D: 95mm (can mounted within a 1/4 DIN size opening)
Maximum Boost Level: 40PSI / 2.72BAR.
What’s in the box:
  • E-Boost STREET control unit
  • Wiring loom
  • Installation kit
  • Solenoid with mounting bracket
  • Vacuum fittings
  • Vacuum hose
  • Hose clamps
This is by far one of the most consistent and EASIEST to use EBC's on the market!
Old Oct 19, 2010 | 11:04 AM
S&R Performance
AEM Tru-Boost Controller & Gauge:
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 PSIg pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 PSIa boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
-No external interface required for programming!
-Complete system includes harness, boost hose, on-board 29 PSIg pressure sensor (external 75 PSIa optional), boost solenoid, gauge display and all necessary fittings
-Quick connect technology eases the installation process
-Two user selectable boost settings with peak boost memory
-Scramble boost setting allows user to momentarily change boost levels
-User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
-User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
-One (1) low-side output included for warning lights
Old Oct 19, 2010 | 01:26 PM
S&R Performance
Default MORE BOOST MEANS MORE FUEL! We got your covered!
We've got the Deatschwerk Injectors that you need to run higher boost levels!
Deatschwerks fuel injectors for the VQ35DE 350Z & G35 feature drop-in fitments for a simple installation. Since they are made from new Denso manufactured injectors, they will fit directly into the stock or any aftermarket fuel rail. Deatschwerks 350Z & G35 fuel injectors will require some sort of fuel management system to work properly (AEM EMS, TurboXS Utec, etc.)
Please specify the size that you need when ordering.
Old Oct 20, 2010 | 08:57 AM
S&R Performance
We all know that AFR is the key to power and performance and good wideband's are a must! We've got some great deals on the very best in the business! Check 'em out!
ProSport Premium Wideband Kit:
Wideband Air Fuel Ratio Gauge
52mm (2 1/16")
Amber/White display-Blacked out when off.
0-5 volt output signal
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9, our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet!
This is a complete kit that includes everything you need:
  • AFR Premium Series Gauge
  • Bosch 4.9 5 wire heated O2 sensor
  • Weld in Bung
  • Instructions
  • Wiring harness(Gauge to O2 sensor) 10 feet long
  • Plug and play
  • Decals
  • Visor/hood
  • Mounting Cup
  • 0-5 volt output signal for data logging
AEM UEGO Wideband:
AEM’s wideband air/fuel gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. The AEM wideband also offers a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
These are our two best sellers and we've got more options on the way! Please let me know if you have any questions at all!
codek
Sep 28, 2015 03:03 AM
