Engine Intakes, Exhausts, Clutches, Turbos, etc...
Injected Performance Solid Motor Mounts are Back!!!!
Old Oct 28, 2010 | 07:42 AM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
Talking Injected Performance Solid Motor Mounts are Back!!!!
We have had many requests for the past year to bring these back and here they are! Our solid motor mounts for the Nisan 350Z and Infiniti G35 are a unique offering to help keep your VQ35 sitting still. Each mount is made using .120 wall Chromoly with TIG welded plates on each end for secure assembly. Each set includes all necessary lock washers and grade 8 nuts. Features a powdercoated gloss black finish that is both durable and stylish. These mounts do not result in excessive NVH, as is often common with solid mounts on other vehicles.
$129 shipped for limited time
You may send paypal to: sales@injectedperformance.com (we must ship to confirmed addresses) or feel free to give me a call to place the order.
Thanks
Dustin
888-465-7373
Old Nov 11, 2010 | 11:49 AM
InjectedPerformance
only couple more weeks at this price!
Old Nov 18, 2010 | 07:34 AM
InjectedPerformance
Early Black Friday Specials!!!!!
Old Nov 19, 2010 | 09:11 PM
jining's Avatar
jining
How is the install on these? I have APS TT kit, curious if its possible to install the mounts by jacking up motor a bit.
Must install solid tranny mount with these?
Old Nov 21, 2010 | 03:08 AM
jining's Avatar
jining
Ok ill order anyways lol hope install doesn't suck toooo much
Old Nov 22, 2010 | 05:22 AM
InjectedPerformance
Yes you can jack up the motor and lower the subframe a little bit and change them out. We had an APS kit in the shop over the weekend we checked to confirm
Just give me a buzz to order or feel free to send paypal to the address above.
Thanks!
Old Nov 22, 2010 | 07:26 AM
jining's Avatar
jining
How much do you need to drop the subframe?
Old Nov 22, 2010 | 07:29 AM
abushong504's Avatar
abushong504
Just remove subframe. Very easy to do. About 11 bolts. Then jack up the motor a bit. Not that bad once you do all of that! Do not need to do solid tranny mounts with this.
Old Nov 22, 2010 | 07:45 AM
jining's Avatar
jining
Im doing it on jackstands so removing it is probably unnecessary :/ I could probably lower it a bit but not remove lol
Old Nov 22, 2010 | 11:40 AM
InjectedPerformance
correct, lower it a little bit and then jack the motor the rest...
Old Nov 22, 2010 | 11:59 AM
jining's Avatar
jining
Alright I hope its not too lame to install. Is it absolutely necessary to lower the subframe? I am doing this on the floor so it will be pretty lame I imagine. Do I need to unbolt all four of the subframe or can I get away with just the back two. Also, I sent paypal payment on sat I believe, aaron baker is my name, did you receive it?
Old Mar 8, 2011 | 06:30 AM
InjectedPerformance
bump to the top
Fixxxercask
Nov 9, 2015 11:10 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
