Widebands Galore! AEM & ProSport Gauges. Killer Deals!
Real power and performance comes as a result of good tuning. We all know this. At S&R Performance, we have one of the busiest dynos in the region so we know this all too well! We work with some of the best manufacturers around! These tools will help you net the very best results out of your build.
AEM Wideband:
The system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The bright LED display shows A/F ratio in .1 increments, and the sweeping LED "needle" lines the edge and changes color as ARF changes from rich to lean. The digital UEGO comes with both silver and black bezels and white and black faceplates that are easily interchangeable.
Key Features:
AEM Analog UEGO:
The system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The backlighting is shared_user adjustable to 7 colors, (white, blue, green, red, orange, light blue, and aqua), allowing users to easily match the wideband gauge to most factory gauge clusters.
ProSport Wideband Kit:
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9, our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet!
This is a complete kit that includes everything you need:
AEM Wideband:
Key Features:
- Accurate to .1 AFR
- Automatically dims and brightens to mactch ambient lighting
- Includes white and black gauge faces
- Includes black and silver interchangeable bezels
- Large LED readout and 320 degree sweeping LEDs for unsurpassed visibility
- Includes Bosch sensor for optimum accuracy and reliability
- 0-5v analog output included for use with data loggers and virtually any engine management system
AEM Analog UEGO:
- Adjustable backlighting via a dial on the back of the gauge
- Two status lights for error detection and operating status
- Available in white or black gauge faces
- 320 degree viewing area for unsurpassed resolutionIncludes
- Bosch sensor for optimum accuracy and reliability0-5v analog output included for use with data loggers and virtually any engine management system
- AFR Premium Series Gauge
- Bosch 4.9 5 wire heated O2 sensor
- Weld in Bung
- Instructions
- Wiring harness(Gauge to O2 sensor) 10 feet long
- Plug and play
- Decals
- Visor/hood
- Mounting Cup
- 0-5 volt output signal for data logging
EVO Wideband Digital Air Fuel Ratio kit
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9 (Prosport Inc. is the only one in the USA to use them) our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet.
Featuring a Dual color (Red or Blue) readout in the center of the gauge and a bar-graph syle LED's around the outside of the gauge for immediate reference to AFR.
AFR digital Gauge
Weld in Bung
Instructions
Plug and play wiring harness
Decals
Visor
This one gauge will display Red or Blue and is dimmable
Includes 0-5 volt output signal for data-logging
Regular Price: $269.00
Sale Price: $209.00
AFR digital Gauge
Weld in Bung
Instructions
Decals
Visor
Sale Price: $209.00
