Engine Intakes, Exhausts, Clutches, Turbos, etc...
TWM Performance - PedalBox offers MORE POWER, FASTER!
Old Aug 9, 2012 | 12:16 PM
TWM Performance's Avatar
TWM Performance
Vendor - Former Vendor
Default TWM Performance - PedalBox offers MORE POWER, FASTER!
Want to get the most of your HP number? Check out our PedalBox Throttle Control Unit from DTE-Systems GmbH! In terms of offering the best bang for your buck and making your car FEEL so much more responsive, there's nothing on the market that comes close. The PedalBox is fine-tuned for your application to ensure that all the settings extracted from OEM throttle data are taken advantage of to the FULLEST. When we installed it in our resident test car (BMW 135i), it made for the most out of those twin-turbos and made the car FEEL like it had less turbo lag and a lot more immediacy. The system can be likened to a car with an old-fashioned cable-controlled throttle body, it's much more of a 1:1 relationship between the throttle pedal and the actual throttle opening; i.e: when the accelerator Pedal is depressed 10%, the throttle body opens 10%. Without a PedalBox Throttle Control Unit, the relationship looks more like this; accelerator pedal depressed 30-40%, throttle body opens 10%. You can see that the relationship is skewed and doesn't provide accurate pedal feel. Here at TWM Performance, we're BIG on FEEL and on making a car as HONEST and as RESPONSIVE as possible. Take a look at the little gem we've been ranting about :P
Just this little module will make ALL the difference! Check it out!
Check out these videos to see how the PEDALBOX THROTTLE CONTROL UNIT works!
www.youtube.com/watch?v=GvkieB5V-Ek&list=UUvcB8DG1P_yVm7DFV1ocL6g&index=6&feature=plcp
www.youtube.com/watch?v=ygRZiJ8CAvI&list=UUvcB8DG1P_yVm7DFV1ocL6g&index=4&feature=plcp
Check out our Youtube Page for some TWM Performance Short Shifter footage!
>> TWM Performance Youtube Channel <<
Renato
Team TWM Performance
Old Oct 22, 2012 | 11:05 AM
TWM Performance
Halloween is coming up shortly! Thanks for your orders this weekend, we're going to be busy today
Short Shifters | TWM Performance Short Shifter Store
Shift ***** - TWM Performance Shift **** Store
Renato
Old Oct 23, 2012 | 06:05 AM
TWM Performance
Camaro short shifter is in! Turn off the lights, turn up the volume and listen to this shifter... it's BRUTAL!
Renato
Old Oct 26, 2012 | 05:37 AM
TWM Performance
TGIF! We're loaded with orders this weekend! Thanks!!
www.Facebook.com/ShortShifters
Renato
EnjukuRacing
Sep 30, 2015 06:55 AM
