Engine Intakes, Exhausts, Clutches, Turbos, etc...
FS: Momentum Performance Turbo Kits and Exhaust -Cheap!-
Old Aug 30, 2012 | 07:48 AM
National Speed's Avatar
National Speed
Vendor - Former Vendor
Exclamation Momentum Performance Turbo Kits and Exhaust -Cheap!-
- We have a few 350Z and G35 Kits available. These will only be sold as a package deal to be installed at National Speed. $7,399 Installed and Tuned! Add $200 for an automatic Z.
The Momentum Performance Single Turbo Kit is capable of producing between 400 WHP (stock motor) and 600 WHP (fully built motor). Two years and 25,000 miles of on-track testing have helped Momentum to develop on of the most durable and highest performing turbo kits on the market.
Reliability is assured through the use of the highest quality proprietary components, such as TIG welded,CNC mandrel bent piping, as well as partnerships with leading aftermarket manufacturers Garret, Tial, Deatschwerks, UpRev and Walbro. The kit’s high end design and components also ensure that it offers a smooth and easy installation process and looks great under the hood – important hallmarks of the “Push Forward” philosophy.
FEATURES
• Garrett GT35R with TiAL 1.03 A/R stainless v-band housing
• Intercooler: Custom high fin density bar and plate (9” x 22” x 3.25”)
• Wastegate: TiAL MV-R
• Blow-off-valve: TiAL Q 50mm
• Downpipe: 3″ 304 stainless with spare O2 bung for wideband installation
• Up-pipe: 2 1/4” 304 stainless
• Intake/Charge Piping: 3″ 6061 Aluminum with an integrated billet MAF housing
• Injectors: DeatschWerks 600cc plug & play (no adapter harness or spacers needed)
• Fuel Pump: Walbro 255 LPH drop in fitment
• Tune: UpRev flash package and basemap (no removing or mailing out your ECU.)
ADVANTAGES
• Coolant Surge Tank: Custom aluminum surge tank
• Supplied with one step colder NGK spark plugs(LFR6A-11) and a K&N Air Filter (5″ x 7″)
• All the necessary hardware, couplers and clamps along with detailed installation instructions
• Polished or optional Powder Coated intercooler and intake tubing (black or gray wrinkle powder coating)
• Polished or optional Ceramic coated exhaust tubing
We also have THREE cat-delete Y-pipes and ONE catted Y-pipe. Only $400 for Cat-less and $550 for one the catted!
The Momentum Performance Y-Pipe is a true track-oriented product specifically designed for hardcore racers seeking to “Push Forward” past the limits of their vehicle’s stock exhaust system.
By deleting the factory catalytic converters and replacing them with the Momentum Performance Y-Pipe not only are the multiple welds and seams of the factory exhaust system eliminated, but important weight savings over stock are also introduced. The Momentum Y-Pipe’s integrated test pipes offer a shallower angle than products offered by many of our competitors and are manufactured out of TIG welded, mandrel bent 304 stainless steel for the ultimate in strength and corrosion protection. The Y-Pipe reduces heat, flow matches exhaust gases for more power production and improves engine breathing.
FEATURES
• 2 1/4” primaries to one 3” secondary
• TIG welded construction
• Mandrel bends for optimal airflow
• 16 gauge 304 stainless steel
ADVANTAGES
• 3/8” stainless steel flanges
• Lightweight construction
We also have Momentum Performance Exhaust Canisters in 2 1/4" and 3" available for $120 each.
Shipping cost is not reflected in price. Call us at (910)332-5901 for any information!
Old Aug 31, 2012 | 05:06 AM
National Speed
Bamp.
Old Sep 5, 2012 | 05:10 AM
National Speed
Bump!
Old Sep 6, 2012 | 05:14 AM
National Speed
Bump!
Old Sep 6, 2012 | 08:00 PM
1991ls13's Avatar
1991ls13
95965 shipped?
Old Sep 7, 2012 | 05:40 AM
National Speed
PM'd
Old Sep 10, 2012 | 05:12 AM
National Speed
Updated with exhaust canisters/Monday bump.
Old Sep 10, 2012 | 09:19 PM
1991ls13's Avatar
1991ls13
dont want to clog the thread but what will this produce on a safe psi and 91 oct? Im trying to building something i dont have to use meth and thats what i usually see with dyno numbers
Old Sep 10, 2012 | 09:21 PM
1991ls13's Avatar
1991ls13
i see it says 400whp but what boost is this? I always see commerical posting` it dynos XXXhp', but never says o its on the highet boost setting and is unsafe to run all the time on 91oct for a dd
Old Sep 11, 2012 | 05:35 AM
Z33Garage's Avatar
Z33Garage
PLEASE STILL HAVE THESE IN A COUPLE OF YEARS WHEN I PAID THE Z OFF!!!
I <3 this kit!
Old Sep 11, 2012 | 05:43 AM
National Speed
You certainly aren't clogging the thread!
All Momentum Performance Single Turbo kits operate on the stock flash level of 8.5-9lbs of boost. I'm going to post a few videos below from recent Momentum Kits we've done, keep in mind NONE of them are on methanol or any other sort of octane supplement, even the 622whp below. On an unmodified flash, you can expect ~400-410whp. We've pulled 622whp on a 93 octane pump gas car and it's still driving today, more than a year of hard driving later, so tuning the car on 91 octane is no problem, there is plenty of headroom left.
Here are a few video examples of Momentum Kits on our Dyno.
2003 Infiniti G35 - Momentum Kit/Dual Exhaust/Unmodified Flash - 409.38whp/393.96lbft
2003 Nissan 350Z - Momentum Kit/Base Flash 409.61whp/382.44lbft
2005 Nissan 350Z - Momentum Kit/Momentum Headers - 426.74whp/415.35lbft
2005 Infiniti G35 - Momentum Kit/8lbs of Boost - 386.40whp/384.29ftlbs
Make note that this power level was generated on 8lbs of boost. We slightly detuned the basemap to prolong life of his stock clutch.
Now if you want to get crazy, you can see the increase in power level with boost in this series of videos. All were done with the same built motor 93 octane 350Z with increasing boost pressures. Keep in mind that this car isn't on meth or with any other octane supplement.
2003 Nissan 350Z - Momentum Kit/Built Motor/7psi- 413.53whp/391.97ftlbs
2003 Nissan 350Z - Momentum Kit/Built Motor/12psi - 518.60whp/513.54ftlbs
2003 Nissan 350Z -Momentum Kit/Built Motor/17psi- 622.82whp/558.10lbft
All that being said, the easiest thing to do is to give us a call at the shop @ 910.332.5901 or give our performance consultant an e-mail at Jordan@nationalspeedinc.com
That way, you can discuss any qualms or questions you had about the kit, or just pick our brains about the best route to go to reach your goal. If you do give us a ring, tell them MY350Z sent you.
Thanks for the question!
Old Sep 11, 2012 | 07:35 PM
1991ls13's Avatar
1991ls13
wow thanks for everything thumbs up.
should have used my car for your advertising and documentation. Looks a whole lot better then that silver one but all n all i like this kit, dont like how i was told momentum went out of busniess from importimage. Another sponser one the site
Old Sep 12, 2012 | 05:28 AM
National Speed
Absolutely!
Alternatively, if you wanted to see more documentation regarding the Turbo Kit install process, we have a few albums of the kits being installed on 350Z's and G35's
Not sure if you need to be a fan of our Facebook or not first to see the albums, though.
Any more questions you ask, feel free to ask in this thread, PM, give us a call or shoot us an e-mail. We are always easily reachable in one form or another!
Old Sep 13, 2012 | 05:56 AM
National Speed
Thursday Bump.
Old Sep 13, 2012 | 12:24 PM
National Speed
Actually, importimage was correct! I don't want misinformation spreading as much as the next guy, and they were right.
We had initially purchased a large amount of Momentum Performance inventory while they were still in business, so everything that we have is our inventory.
Old Sep 14, 2012 | 05:07 AM
National Speed
TGIF!
Old Sep 15, 2012 | 10:06 AM
National Speed
Hope everyone is having a good weekend.
Old Sep 17, 2012 | 05:16 AM
National Speed
Happy Monday, Everyone!
Old Sep 17, 2012 | 01:41 PM
National Speed
Afternoon Bump.
Old Sep 18, 2012 | 06:46 AM
National Speed
Happy Tuesday!
