FS: HKS Twin Power DLI II Ignition Kit
Old Sep 21, 2012 | 05:53 PM
reptile718's Avatar
reptile718
Default HKS Twin Power DLI II Ignition Kit
Up for grabs is an HKS Twin Power DLI II Ignition Kit which comes in its original box with instructions and harness. Valued at over $500 and no longer made its hard to come by.
The harness that's included is vehicle specific and not for the Z although the main unit is made for a variety of cars including the Z. Got it from a friend with the hopes of making my own harness out of the existing one but never got around to it, should not be hard at all if you have some basic wiring knowledge.
Unit is in perfect working condition and looks new minus a scrape on the bottom back of the unit which is not visible when installed.
Letting it go for a steal: SOLD!
If you have any questions please feel free to send me a PM.
Thanks for looking!
From HKS:
The HKS Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power.
The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. Expect a spark output that is typically 1.5-2.5 stronger than that of the stock ignition system! Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration. This is a perfect upgrade for your 2003-2006 350Z or G35. Even with mild modifications an ignition amplifier will give you better throttle response and a stronger spark.
Old Sep 23, 2012 | 05:53 AM
reptile718's Avatar
reptile718
Price Drop
Old Sep 24, 2012 | 04:44 PM
reptile718's Avatar
reptile718
Bump!
Old Sep 24, 2012 | 09:33 PM
reptile718's Avatar
reptile718
PM's Replied, Sale Pending...
Old Sep 24, 2012 | 11:54 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Let me know if the sale falls through.
Old Sep 25, 2012 | 11:33 AM
sarutj_z33's Avatar
sarutj_z33
I'll take it too...
Old Sep 25, 2012 | 02:14 PM
b18ccivics's Avatar
b18ccivics
sold to me
Old Sep 25, 2012 | 03:08 PM
reptile718's Avatar
reptile718
SOLD!
Old Oct 5, 2012 | 04:18 PM
b18ccivics's Avatar
b18ccivics
Old Oct 5, 2012 | 05:25 PM
reptile718's Avatar
reptile718
Sorry have been out of town all week on business, I have updated the track info through PAYPAL, thanks!
