FS: 2003 VQ35DE Part Out w/ JWT S1 Cams
Old May 27, 2013 | 03:13 PM
98gsxin's Avatar
98gsxin
Default 2003 VQ35DE Part Out w/ JWT S1 Cams *Price drops*
This motor was pulled from my 2003 z w/ only 56k miles on it. I was experiencing a loss in power. There was low compression in cyl 5. Turns out that one of the rods was bent and preventing the piston from reaching TDC. I inspected the block and there seems to be no other damage. There is still cross hatching in the cylinder bore and the crank spins freely like butter. The motor is currently stripped down to the block with the crank in it. The pistons and rods have been removed. The heads were removed. The cams were removed from the heads. The cam caps will remain with the heads. If you are interested in any parts that aren't listed, just ask and I will see if I still have them. All prices plus paypal and shipping. Local pickups in the bay area are welcome. (Santa Clara) Make an offer and I can bundle things together for a deal.
Added:
Timing Chain Guides (all 3) $100
Intake Timing Gear (only 1 left) $75
Crank Pulley and Sprocket $50
Timing Chain $50
Rod and Piston (assembled. each. 5 good ones available) $50
JWT S1 Cams SOLD
Heads w/ lifters, shims, valve springs, retainers, valves $250
Valve covers (both) SOLD
Block w/ crank SOLD
Engine Mounts $75
Front and rear timing covers SOLD
Upper oil pan (has hole tapped into it for oil temp sensor) SOLD
Coolant pipes $40 each
Coils (all 6) SOLD
Fuel injectors and rails $75
Intake plenum $125 (upper and lower. I started sanding and polishing it, but got lazy. It's about half way there.)
Stillen Headers $300 (no cracks, holes or rust)
Last edited by 98gsxin; Jul 6, 2013 at 02:15 PM. Reason: update on parts price and availability
Old May 27, 2013 | 08:14 PM
INGSZ33's Avatar
INGSZ33
Sent PM on set of coils
Old May 28, 2013 | 06:12 AM
zeusthefrog's Avatar
zeusthefrog
I want the block with the crank and also if you have the upper oil pan , I would like that too... Quote for 08691 .. Very serious about the purchase
Old May 28, 2013 | 09:30 AM
INGSZ33's Avatar
INGSZ33
Sill waiting on his reply as well.
Old May 28, 2013 | 11:29 AM
G35CDriver's Avatar
G35CDriver
pm sent
Old May 28, 2013 | 09:39 PM
Zjul8r's Avatar
Zjul8r
Selling just injectors? Size? Manufacturer?
Old May 28, 2013 | 09:53 PM
J.navarrete9722's Avatar
J.navarrete9722
Email me j.navarrete9722@gmail.com I want the block
Old May 29, 2013 | 02:47 AM
RodiZio's Avatar
RodiZio
Hi, would you come down to $350 on the cams, I can pay today. Thanks
Old May 29, 2013 | 03:31 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Valve covers leak? Pm me I may take them
Old May 29, 2013 | 07:32 AM
98gsxin's Avatar
98gsxin
All PM's replied. The shipping quotes for the block are kind of hard to get, but I'm working on it. It's going to be expensive to ship it cross country though...
Old May 29, 2013 | 05:58 PM
CTS13's Avatar
CTS13
You tore apart the whole block cuz of one bent rod. You could have just replaced the one rod and it would have good again.
Old May 30, 2013 | 08:30 AM
98gsxin's Avatar
98gsxin
Didn't know it was bent until I removed it from the car. Already had another block ready to go, so I swapped that one in the car without dealing with this one. I'll make more money parting this block out than selling it whole. Mind your business.
Old May 30, 2013 | 08:39 AM
2004Black350z
Exhaust Whore
Haha
Old Jun 4, 2013 | 03:06 PM
98gsxin's Avatar
98gsxin
Coils, valve covers, and timing covers sold.
Timing chain guides, intake cam gears, rods and pistons added.
Old Jun 6, 2013 | 12:08 PM
95maxrider's Avatar
95maxrider
PM sent!
Old Jun 7, 2013 | 04:50 AM
sracura's Avatar
sracura
Pm'd you.
Old Jun 11, 2013 | 10:02 AM
boosted04z's Avatar
boosted04z
Pmed
Old Jun 11, 2013 | 10:43 AM
sracura's Avatar
sracura
Pm'd you again on the crank and cams, paypal ready let me know
Old Jun 11, 2013 | 11:38 AM
Antlaw's Avatar
Antlaw
How much for the intake cam gears? Also, do you have the VVT solenoids?
Old Jun 11, 2013 | 01:48 PM
Sjontonn's Avatar
Sjontonn
Pm'd
