(OEM) FS: Vq35de rev-up oil pump genuine nissan oem
Old Mar 28, 2015 | 05:32 PM
datboyvinh's Avatar
datboyvinh
Default Vq35de rev-up oil pump genuine nissan oem
Oil pump from '06 Rev-Up motor.
This pump is a direct replacement for all VQ35DE motors from 03-07 (non-HR) engines. The pump was designed to handle the '06 redline increase to 7,000 RPM's. This is the pump we would use anytime we rebuild or replace an oil pump in a DE engine
Description:
BRAND NEW FACTORY OEM NISSAN INFINITI OIL PUMP ASSEMBLY FOR REV-UP ENGINES
This item is a Genuine NISSAN OEM OIL Pump for your VQ35 engine. Strongly recommended when swapping in a used motor, rebuilding your motor, or even going forced induction . It is always a smart idea to replace this pump when doing any sort of rebuild work since the water pump is fairly difficult to change out. Over time, debris can clog the pump or the seals which causes the pump to wear and tear which eventually causes it to not operate at its full potential.
PERFECT PUMP FOR FORCE INDUCTED ENGINES.
Application: VQ35DE ENGINES ONLY
$180 Shipped
Old Mar 29, 2015 | 04:09 PM
datboyvinh's Avatar
datboyvinh
Will accept reasonable offers
Old Mar 29, 2015 | 11:49 PM
honeycombe's Avatar
honeycombe
How much shipped to Australia QLD 4810
Old Apr 5, 2015 | 02:31 PM
datboyvinh's Avatar
datboyvinh
Need it gone !!
Old Apr 6, 2015 | 08:09 PM
datboyvinh's Avatar
datboyvinh
Sold please close thread. Thank you
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
