350Z 2JZGTE VVTi Swap Wiring Harnesses now Available - Wiring Specialties
Plug and Play for the 350Z. Available with many aftermarket options.
The Wiring Specialties 2JZGTE VVTi wiring harness is ideal for those looking for the best in aesthetics, weight savings and reliability.
Our harnesses are designed from the ground-up to exceed OEM specifications for wire quality, power/ground routing. With our optimized and 'tucked' approach the end result will be a clean and worry free installation with a guaranteed start up. Completely replace your old OEM harness and never worry about electrical gremlins again.
http://www.wiringspecialties.com/1j2jharness.html
PRO-SERIES HARNESS SPECS:
PRO-SERIES HARNESS INCLUDES:
- Plug and Play – simple and efficient
- NO CORE HARNESS or additional wiring required
- OEM wire colors used, where applicable
- All sensor signal connection use EM shielded wires
- Fireproof fiberglass sleeving used in high-temp sections near the manifold & turbo (-40°C/-40°F to +450°C/+845°F operating temperature)
- Point-to-Point continuity tested on every wire
- Constructed using exact OEM connectors and seals
- Made with high temp TXL wire with adhesive shrink tubing (-40°C/-40°F to +125°C/+257°F operating temperature)
- Wrapped in lightweight nylon loom (-94°C/-137°F to +125°C/+257°F operating temperature)
- Includes a charge harness and improved grounds
- Fully tested after production for an easy plug-and-play installation
- Main Engine and Transmission one-piece tucked harness
- 3x Coilpack connections
- 2x Knock sensor connectors
- MAP connector
- IAT connector
- TPS connector
- Boost solenoid wiring (with AEM/Haltech or aftermarket computers)
- VVT-I connector
- 10-pin igniter chip connector (relocated to inside the car)
- 2x CAM sensor connector
- Crank sensor connector
- Throttle motor connector
- OEM Oxygen sensor connectors (wideband wiring is not part of the EFI harness, except AEM Infinity 6/8)
- 2 x Ground ring terminal
- ECT sensor connector and cluster coolant temp switch connector
- Reverse lights sensor connector
- Speed sensor connector
- Alternator connector
- Starter signal connector
- OEM oil pressure 1-pin connector
- Speed and Tach signal converter connector
- ECU Diagnostics mode connector
- ** No traction Control wiring supplied
- Printable install instructions with pictures
- Turn Key ENGINE START Guarantee
75mm throttle body big bore upgrade plug and.play harness can i get one of.those from you guys. 2004 touring convertable at
I am.newb here just got.car been looking every where thanks
MA-Motorsports
Body Interior
Aug 31, 2015 07:54 AM
Chops@MVP
Sep 17, 2013 11:10 AM
Dynosty
Jul 31, 2012 09:42 AM
