sanding headlight housing for paint, what grit? help!
Old Dec 26, 2004 | 11:51 AM
nureulsaranghae's Avatar
nureulsaranghae
Default sanding headlight housing for paint, what grit? help!
hi guys, I am about to paint my headlight housing black tonight. But I was wondering what grit sandpaper I need to sand these down? asap reply will be appreciated since I will be doing the job in 3hrs.
thanks guys
John.
Old Dec 26, 2004 | 12:50 PM
Conceyted's Avatar
Conceyted
bump, i need this info too!
Old Dec 26, 2004 | 12:52 PM
ssc's Avatar
ssc
please post pics after..i am very intersted in see what you mean by painting your headlight housing
Old Dec 26, 2004 | 01:05 PM
nureulsaranghae
sure will,b ut I need this answer now! help guys!
Old Dec 26, 2004 | 01:48 PM
manofsteele2003's Avatar
manofsteele2003
I'm assuming you mean the inner headlight housing right? If I were you I'd go with a really light grade sand paper just enough to scuff up the surface so the paint sticks. You might even be able to go with a scotch pad.
If you use a really rough sand paper you will get really deep scratches that will probably be visible after you paint it. Always start with the lightest and if it is not enough you can always go a little rougher.
Old Dec 26, 2004 | 05:19 PM
zerog's Avatar
zerog
1000,1500 or 2000... should work...
ZeroG
Old Dec 26, 2004 | 08:02 PM
Conceyted's Avatar
Conceyted
i am thinking of maybe not even sanding, you can buy a primer made to stick to smooth plastic surfaces. I found a piece of plastic that resembles the properties of the headlight housing and i used some of the primer i found, and it stuck on there very nicely. 2 coats of satin black over it and it looks amazing. I am thinking maybe not sanding at all?
Old Dec 26, 2004 | 08:04 PM
zerog's Avatar
zerog
make sure you use some thinner or something to pull all the oil off the assembly.....
ZeroG
Old Dec 27, 2004 | 09:15 PM
nureulsaranghae
hey guys, here is the finished product for those of you who were interested in seeing them!
more day pics will be coming soon.
thanks
John.
Old Dec 28, 2004 | 03:40 AM
aznmojo's Avatar
aznmojo
when u paint the headlight housing, u left out the projector lense and the reflector under it. Were those detachable? Or did u have to mask it? nice work btw.
Old Dec 28, 2004 | 07:10 AM
Conceyted's Avatar
Conceyted
they are detatchable... theres are multiple pieces in the headlight assembly
Old Dec 28, 2004 | 08:08 AM
konspec's Avatar
konspec
all I used on mine for sanding was a scuff pad. Thats all that is needed sand paper if overkill plus it harder to use in the creases. All peices painted in that picture come out seprately. The most annoying part of the job for me was getting the hid bulb locked in.. booo Other then getting past the fact that your tearing apart very expensive and new headlights the job is easy, just take it virgin( nice and slow)
Old Dec 28, 2004 | 09:17 PM
ssc's Avatar
ssc
look pretty good, man
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
JGee450
Sep 30, 2015 04:32 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
