why is 1 of my ARES led sidemarkers now intermittently blinking?
Old Jan 1, 2005 | 08:46 PM
sicilianoNYC's Avatar
sicilianoNYC
Default why is 1 of my ARES led sidemarkers now intermittently blinking?
i was in buckhead tonight (the club strip in downtown ATL) and noticed through the reflection on a building that my right LED sidemarker is now intermittently blinking and its a fast blink, the other side is perfectly fine. What could have caused this? And its doing it while the car is off and i just have the headlights on.......weird....
Old Jan 1, 2005 | 09:15 PM
hndumafia's Avatar
hndumafia
check to see if any of the other bulbs on that side of the car are dead. usually when one of the bulbs goes dead one of the other bulbs blinks fast so you know there is a dead bulb.
Old Jan 1, 2005 | 09:27 PM
sicilianoNYC
jus checked and nothing on that side of the car is dead, but like i said there is no rhythm to the blinking it could be fast or slow and then itll be ok for a couple mins then start again, **** is weird
Old Jan 1, 2005 | 10:22 PM
Strife350z's Avatar
Strife350z
did you use tap-splices? check to make sure those are secure... just a shot in the dark, but i used tap-splices on mine and the first time i turned on my parking lights (wired to the sidemarkers) they turned on and off intermitently because the spliced connection was not secure
you may need to buy a new tap-splice or hard wire it altogether
good luck
Old Jan 2, 2005 | 10:19 AM
bigfatjeffk's Avatar
bigfatjeffk
i had this problem with one of my new ARES bulbs. I ended up returning it for a replacement. In my case it was one of the tiny wires that is part of the ARES bulb that wasn't lined up correctly.
Old Jan 19, 2005 | 04:05 AM
Jun's Avatar
Jun
maybe it blew. is it like a flicker more than a blinking?
lolwatbro
Oct 9, 2021 04:58 AM
Juztin
Nov 22, 2015 07:03 AM
davidm350
Oct 31, 2015 02:28 PM
Mw870
Oct 2, 2015 08:23 AM
ddegrande21
Sep 6, 2015 11:15 AM
