Weight in trunk??? spoiler too heavy!!
Old Feb 21, 2005 | 02:13 PM
tonester1011's Avatar
tonester1011
CF God
Default Weight in trunk??? spoiler too heavy!!
Ive read somewhere in here that there is a weight of some sort in the trunk that will make it a little lighter and easier for the trunk to open after putting a spoiler on it. I got the veilside ver 1 and now it seams like the trunk doesnt want to stay up that easy. Is there somethin in there that can be taken out to make the trunk a little lighter. Any help would eb appreciated.
Old Feb 21, 2005 | 02:30 PM
westpak's Avatar
westpak
SFZCC
If you remove the rear panel off the hatch you will see a black weight which can be taken out.
Other than that you will probably need new shocks to hold it open, mine is fine witht he fiberglass Nismo replica, it is a little hard to open but it stays open, some of the other spoiler hang further back on the hatch so they put more pressure on the shocks than the Nismo does which hand in from the edge.
Old Feb 23, 2005 | 01:44 PM
syf0n's Avatar
syf0n
Where is the weight exactly?
Old Feb 23, 2005 | 07:11 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Here is where it is. This was was already removed.
Attached Thumbnails Weight in trunk??? spoiler too heavy!!-remove-weight-here.jpg
Old Feb 23, 2005 | 07:13 PM
islandsnow's Avatar
islandsnow
you can grab the lower plastic cover (that covers the rear windshield wiper motor) almost anywhere and pull and it will start popping the cover off the bottom of the hatch, be careful if you pull from the sides first, there's different clips near the top. But if you pull it straight out it should be fine. Once you pull it off, right dead center is a retangular black bar with like butterfly rails, (can't describe it, theres a picture online someplace) But it has 4 screws. You can't miss it. It's cake to unscrew that and pop the plastic cover back on. My hatch stays up now, but i had to do the 2 penny trick and the furniture pad trick too to make it pop 100% everytime without having to hit the unlatch button again.
Old Feb 24, 2005 | 11:22 AM
tonester1011
CF God
Thanx for the help fellas!
Old Feb 24, 2005 | 11:51 AM
tonester1011
CF God
I just looked at mine and there was nothing there...I already had the plastic out cuz i didnt put it back in yet and there are the 4 screw holes right there but there are no screws or anything in there....anyone know y????
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
