Where can I get LED Parking Bulbs for the Z?
Old Mar 16, 2005 | 05:42 AM
mcduck's Avatar
mcduck
Default Where can I get LED Parking Bulbs for the Z?
Bought some of ares LED bulbs last year and they look great since they burn the same color light as the headlights instead of yellowish.
Only problem is ares website looks like he's no longer doing the LED bulbs and I have not been able to reach him via email. I now need two more sets (one bulb burned out or was damage during a recent headlight modification and I want a set to go behind the reflector strip).
Anyone have a source for these?
Old Mar 16, 2005 | 06:28 AM
Z CRUZN's Avatar
Z CRUZN
Hi buddy! I picked some LED's up from www.superlumination.com - takes about 10-12 days to get them from AZ, but they are pretty good quality. Picked up reverse lights (7440 - 15 LED), map lights (festoon - 9 LED), & parking lights (168/194 - 5 LED) - reasonably priced. The Bright Whites are a white/blue shade - match great with the headlights. Hope this helps.... Jack
Old Mar 16, 2005 | 08:23 AM
Losing Grip II's Avatar
Losing Grip II
Jack you ***** dont you know its not good to lie to people the festoon lights are only available in 31mm for our cars and they are 4 leds.
you can kill me if im wrong
john
Old Mar 16, 2005 | 10:32 AM
mcduck's Avatar
mcduck
More questions... (BTW, thanks for the link)
Are these bulbs same wattage rating as normal bulbs? I don't want to run hotter bulbs under the reflector strip.
Also, any thoughts on which variety is best (opaque, focused, etc). I'm leaning the opaque or the inverted. Not looking of a pinpoint beam of light, just a normal light that matches the headlight color.
Old Mar 16, 2005 | 10:42 AM
Losing Grip II
i have the opaque single led for the parking light. i too didnt want the light beam idea, the soft glow is as bright but the beam is more scattered and looks more natural.
john
Old Mar 16, 2005 | 10:52 AM
ares's Avatar
ares
Veteran
leds wont ever cause a heat problem; nor any issues with wiring gauge ect. they use very little current. only issue you will have is if you use them for turn signals the car wont know their even plugged in.
Old Mar 16, 2005 | 11:02 AM
Z CRUZN's Avatar
Z CRUZN
john
I won't kill you , BUT the 39mm (1 1/2") 9 LED festoon works PURRfectly in our map lights - a little longer than stock, but fit perfectly. Several of us here have done them & they are sweet!! Here's the original thread that turned me on to them.... hope it helps!
https://my350z.com/forum/exterior-and-interior/106005-led-parking-lamps-and-led-interior-lights-pics-inside.html
Old Mar 16, 2005 | 02:09 PM
Losing Grip II
https://my350z.com/forum/showthread.php?t=106005
DAM.....
im a loser.
does anyone know as to why those lights are called "festoon"s?
im in the dark on that one.
john
Old Mar 16, 2005 | 05:27 PM
ares's Avatar
ares
Veteran
*shrug its just what they call those cylinder shaped suckers. on the same hand Im not sure why all the 7440 168 ect are called wedge. its just their name
Old Mar 16, 2005 | 05:28 PM
Losing Grip II
ok.
now sell me some clear strips damit
john
Old Mar 16, 2005 | 07:02 PM
Z CRUZN's Avatar
Z CRUZN
DAM.....
im a loser.
john
festoon - "a decorative chain or strip hanging between two points" ... according to Mr. Webster.
Old Mar 16, 2005 | 09:45 PM
Losing Grip II
That was slick my friend, very, very slick.
Old Mar 17, 2005 | 05:52 AM
mcduck's Avatar
mcduck
Thanks for the info guys. Ordered two types yesterday. Don't remember which ones, but they were not the opaques, they were the ones with 100 degree illumination arc. Ordered a single set of the Matrix LEDs. Will use whichever looks best
Only using them for parking bulbs and reflector strip bulb so the turn signal thing should not be a problem.
Thanks!
Old Mar 17, 2005 | 02:09 PM
dkny_boi's Avatar
dkny_boi
I can kinda see why... their bases "wedge" tightly into the harness, instead of the others that sit in, and twist to lock in?
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
