Swapping out parking/turn bulbs in rear
Old Mar 17, 2005 | 10:52 AM
Synergy350Z's Avatar
Synergy350Z
Default Swapping out parking/turn bulbs in rear
Can anyone give me a part number and place to order these?
I couldn't find anything on search. I replaced the fronts already, are they same bulb?
I just want to put in some hyperwhites instead of the stock ambers.
Thanks in advance.
-Travis
www.TeamSynergySD.com
www.CourtneyDay.com
www.groups.yahoo.com/group/CourtneyDayGroup
Old Mar 17, 2005 | 11:52 AM
owali1's Avatar
owali1
http://www.sylvania.com/ConsumerProd...de/default.htm
Old Mar 17, 2005 | 11:58 AM
Synergy350Z
Hmm a 168 huh? Never even heard of it. Hopefully I can find it locally. Thanks bro!!
-Travis
www.CourtneyDay.com
Old Mar 17, 2005 | 01:44 PM
dkny_boi's Avatar
dkny_boi
The "parking lights" in the rear, are in the brake lights, little bulbs that just light up the bottom of it at the side (which is the 168/194 size... they're pretty much same thing).
If you want to replace the rear turn signal lights with the hyperwhite, then you'd need a bulb like the front turn signal which should be a 7440.
Not sure why you want hyperwhite though... it's kind of annoying seein the car in front of you with a super bright blue-ish white light blinking instead of red/amber when he's turning/switching lanes.
Old Mar 17, 2005 | 02:05 PM
ares's Avatar
ares
Veteran
the "parking lights" in rear as were said are in the brake light housing, and would be useless to replace since they are behind a red lens anyway.
both bulbs in the combo light housing(turn signal and reverse light) are 7440.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
