Cracked Front Lip
Old Mar 27, 2005 | 11:21 AM
Eddie1979's Avatar
Eddie1979
Default Cracked Front Lip
Just bought a new Z and theres a big crack down the center of the front lip. What are my options? Should I patch the crack and paint or can I replace the lip without replacing the whole bumper? I don't have the car for another week otherwise I'd post a pic.
Old Mar 27, 2005 | 12:25 PM
kinjal's Avatar
kinjal
the stock z does not have a front lip. is this an aftermarket lip? if so, what kind? or are you talking about the little black piece under the front bumper (front air diffuser)?
Old Mar 27, 2005 | 12:32 PM
Eddie1979's Avatar
Eddie1979
Ah crap i guess the actual bumper is cracked then. It's not the whole bumper though just the section under the black grill, cracked right down the center.
Old Mar 27, 2005 | 01:11 PM
synth19's Avatar
synth19
you're right. The bottom portion of the bumper (which you are referring to as a lip), is part of the bumper. You can't replace that part, you would have to replace the entire front bumper. In this situation I would just add an after market front lip to cover the damaged part. I did that, I had a small crack on the bottom, my Veilside lip covered it up nicely, plus it enhanced the look of the front. Not sure if this idea will work for you, depends on the extent of your damage.. pics would help.
Old Mar 28, 2005 | 09:40 AM
Eddie1979's Avatar
Eddie1979
Yup i'll post a pic this weekend when i bring her home. The crack is big though, runs from from top to bottom (of lower bumper). I recall seing a carbon fibre thing that wraps around this area. That might work.
Old Mar 28, 2005 | 10:18 AM
B-Unit's Avatar
B-Unit
You could take the front bumper off and lay some fiberglass down if you know how to work with fiberglass, otherwise youll prolly have to take it to a shop.
Old Mar 28, 2005 | 01:03 PM
Eddie1979's Avatar
Eddie1979
I'm thinking of getting one of those carbon fibre lower front bumpber overlays like bluebatmobile sells, or the CF EVO-R one. That should hide the crack nicely and still look okay at the same time.
Obadabot
Jun 18, 2023 11:31 PM
Twenty4
Jan 17, 2016 01:20 PM
