clear bumper reflector install - PIA!
Old Nov 19, 2002 | 05:25 PM
N74DV's Avatar
N74DV
Default clear bumper reflector install - PIA!
I thought it would be easy to install my clear bumper reflectors..... yeah right!
those screws that hold the relfector on are BURIED inside there.
The left side is not too bad, but the right side has the washer fluid tank exactly in the way.
I had to drop the entire front bumper wich is easy until you have to unscrew the two screws inside by the headlights.
Finally I managed to remove the bumper.
The relfectors will be installed first thing tommorow morning.
It is nice to know that if something should ever happen to the bumper and it needed replacing, it's a job you can do yourself in about 30 minutes. Once the fasteners are removed it comes right off.
Old Nov 20, 2002 | 04:11 AM
j's350z's Avatar
j's350z
I was able to install the clear reflectors without removing the bumper. I had to lay on my back and go in from the front under the bumber. It was a pain in the ***, but I used a screwdriver bit and a ratcheting open end. The passenger side took a half hour and the drivers side took about 5 mins.
Jason
NJ
Old Nov 20, 2002 | 08:09 AM
wadd3456's Avatar
wadd3456
Where did you buy your clears and what did you pay shipped?
Old Nov 20, 2002 | 08:38 AM
N74DV's Avatar
N74DV
japanparts.com did an ebay auction for a set. I ended up winning the bid at $55. shipping was $12 and I got them in less than a week.
now that they're installed I really dig 'em. Big difference over those stocker ambers
Old Nov 21, 2002 | 04:29 AM
j's350z's Avatar
j's350z
same here.....japan parts.com. $55 bucks and around $15 for shipping to NJ. I had them for about a month before my car even came in...Graham is a lot of help there in Japan. Just email him if you have any questions.....
Jason
NJ
Old Nov 21, 2002 | 06:37 AM
afr0puff's Avatar
afr0puff
Can you post pics?
Old Nov 21, 2002 | 07:00 AM
westpak's Avatar
westpak
SFZCC
Originally posted by afr0puff
Can you post pics?
I did mine, here are some shots.https://my350z.com/forum/showthread....&threadid=8873
Justin100
Nov 25, 2021 06:26 AM
sales@czp
Sep 23, 2019 03:30 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
