Base Headlight to Xenon Headlight?
Old Apr 20, 2005 | 02:36 PM
ecorona6's Avatar
ecorona6
Default Base Headlight to Xenon Headlight?
Does any one know if I can switch my Base Halogen headlights for Xenon headlights. I am pretty sure the headlight plugs are different, but what would I need to do in order for them to run right? Would the ballast burn my fuses or computer? Any help would be appreciated!
Old Apr 20, 2005 | 05:01 PM
GWAPITO69's Avatar
GWAPITO69
i converted my halogen lights wid HID. don't know if that's what you're reffering to but i got the stock ballast and hella HID light. it's easy to install just have to cut the connector that you have and put it on the connector that is supplied with the HID. Good luck. i know some of the base owners here did thesame stuff.
Old Apr 20, 2005 | 06:57 PM
ecorona6's Avatar
ecorona6
Originally Posted by GWAPITO69
i converted my halogen lights wid HID. i got the stock ballast and hella HID light. it's easy to install just have to cut the connector that you have and put it on the connector that is supplied with the HID.
It answers one question...I can get a 350Z headlight connector equipped with Xenon lights and cut my 350Z base model (non-Xenon) connector and wire it up so that I can simply connect the Xenon headlight!
Is this true?
Is your Hella HID light a kit? Do you have pics?
I dont want a HID kit, but rather use the stock 350z Xenon (Projector) healight instead. HELP!!!
Old Apr 21, 2005 | 07:42 AM
Badfish25's Avatar
Badfish25
I got my Kit from Jun on here. If you want to change out to xenon projector you will most likely have to buy the whole headlight housing which equals around $1000 plus the ballast and bulbs. it looks to me though that if you could open up the headlight housing you could unscrew the projector part and screw in a xenon projector, of course the problem is finding a xenon projector without it being in a headlight. maybe try finding a junk yard with a dead Z.
Old Apr 21, 2005 | 08:07 AM
ecorona6's Avatar
ecorona6
I am not explaining myself well.....
I want to switch out my whole entire Halogen headlight and replace it with a whole entire Xenon headlight (350z), but I dont know if my halogen headlight connection will fit the Xenon headlight. What connections do I need? And should I be concerned of the power it need?
Old Apr 22, 2005 | 12:08 AM
2005350z's Avatar
2005350z
check the online manual for infiniti
Old Apr 22, 2005 | 07:54 AM
newmexicoZ33's Avatar
newmexicoZ33
....I didn't think there were any differences in the actual headlight between Xenon and non-xenon. You just need the ballasts and harnesses and bulbs. I think people have answered your question, you are just not understanding the answer. Send an email to user Jun on this forum. He sells plug and play kits to upgrade to Xenon using the stock ballasts.
Old Apr 22, 2005 | 09:08 AM
GWAPITO69's Avatar
GWAPITO69
ok here's some pics of my base z with HID. the car is few inches away from the garage door.
Attached Thumbnails Base Headlight to Xenon Headlight?-img_0001.jpg   Base Headlight to Xenon Headlight?-img_0002.jpg   Base Headlight to Xenon Headlight?-img_0003.jpg
Old May 12, 2005 | 12:04 AM
topdaytrader's Avatar
topdaytrader
check out http://www.motionr.com
Old May 12, 2005 | 08:09 AM
jhp1025's Avatar
jhp1025
I have switched out the halogen bulbs and replaced them with Mcculloch HID Kits on three vehicles now. I am very pleased and it is plug and play. I order my kits on ebay. Just search Mcculloch HID and there is a seller; supervtec, that sells 4 different temperature bulbs for all light fitments. I like the 6000K myself.
Good luck.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
JGee450
Sep 30, 2015 04:32 AM
