LED Sidemarkers (Need opinion)
Old Apr 29, 2005 | 10:37 AM
donricouga's Avatar
donricouga
Originally Posted by ares
nope with the wiring setup you have you would need the same resistor for a single LED as for all of those; that being about 550ohms.
at 9volts you should have used a 275-300ohm resistor! your at about 400mA at 15ohms on 9volts. double check your resistor they should have surely fried at that current level. within like milliseconds lol. 400mA is WAY out there.
LOL, they didn't fry. It works just fine. The led's themselves act like resistors or so I was told. I mean they are just diodes.
Ohm's Law for my case of a 9v battery.
(v1 - v2) / (I*ledcount / 1000)
(9V - 3.5V)/(20mA * 42 / 1000) = 6.55 ohms
So I use a 10 ohm limiting resistor. for the 9 V battery. It lights up well. Thats how i took the pics
I hope i didn't miss anything. In any case. I will attach 275 -300 ohm resistor like it and see what happens. I suppose the worst that can happen is it doesn't turn on. I will write back maybe this weekend with my results.
Old Apr 29, 2005 | 01:25 PM
ares's Avatar
ares
Veteran
well yes... unless I have my definitions wrong(I hope not; but not ruling it out yet) that led count would be for LEDs in a series; not parralel. making your LED count 1. resulting in the aforementioned 275ohm number...
if you had 2 in series; itd be (9-7)/(40/1000)
the 7 being the voltage adding up.
at 3 you would have 10.5 being why you really cant go to 4 in a series because you dont have enough volts. you actually have extremely close to the correct voltage at 4; but I tried to "skip" the resistor and it was really just better to use 3 and keep a resistor.
to be honest; Ive always used an online calculator to do it lol; Im lazy. online calculators only request number of LEDs in series; voltage for each, mA, and supply voltage. they never mention anything about LEDs in parrellel which makes me assume you'd use only those in series for the equation as well.
from what I know; and have done; you could cut that down in that wiring setup and go to 10LEDs, or 1 LED, and the resistor would not change at all. the current still passes from positive-resistor-single LED-negative; it has 42 paths to do so; but that makes no nevermind to the resistor if it has 42 or 1.
Old May 1, 2005 | 05:48 PM
donricouga's Avatar
donricouga
Well I finished the project pics are attached. I did end up using a 5W 15ohm resistor as a limiting resistor. I taped into the positive end on the parking wire and the negative end i simply attached it to a screw.
Attached Thumbnails LED Sidemarkers (Need opinion)-wired.jpg   LED Sidemarkers (Need opinion)-frontview.jpg   LED Sidemarkers (Need opinion)-sideview.jpg   LED Sidemarkers (Need opinion)-detailed.jpg
Old May 1, 2005 | 07:25 PM
thunder0880's Avatar
thunder0880
i couldnt see it looking bad either way. nice job with the leds.
Old May 1, 2005 | 07:47 PM
Acree's Avatar
Acree
those look great man. man that picture sure does look familiar.
Old May 2, 2005 | 05:33 AM
donricouga's Avatar
donricouga
lol, i guess it does. I love the way it looks from the front. IMO it looks better from the front than from the side.
wanderingstuden
Jan 28, 2016 07:03 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
kyin
Oct 15, 2015 05:54 AM
Mw870
Oct 2, 2015 08:23 AM
samansharif
Sep 25, 2015 12:31 PM
