Removed Rear Windshield Wiper
Old Apr 30, 2005 | 03:04 AM
Michla22's Avatar
Michla22
Default Removed Rear Windshield Wiper
Well I decided to remove my rear windshield wiper. I never used it much and I'm very happy with how the car looks without it. The removal was very easy. The hardest this was finding the right cover to cover the hole. Anyways here are some pics:
If you don't ever use your rear wiper I would recomend removing it , it's easy and looks great.
Old Apr 30, 2005 | 06:45 AM
2 low Z's Avatar
2 low Z
Looks great. Do you have any close up shots of the plug and what plug did you use?
Old Apr 30, 2005 | 07:54 AM
ghost11's Avatar
ghost11
it does look good, can you do a write up? and closer pics
Old Apr 30, 2005 | 08:25 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
good ****, i have been wanting to do this as well, figure i will just rainX the rear window. So much cleaner looking. K so thats my next project.
Old Apr 30, 2005 | 08:39 AM
Z-INCOGNITO's Avatar
Z-INCOGNITO
Welcome to the Rear Wiper Less Club...
Old Apr 30, 2005 | 08:47 AM
ssc's Avatar
ssc
hmmm....for some reason i like it better with wiper on there...i guess i am so used to looking at my z with that wiper on there that when i see your car, it seems like it's "missing" something
Old Apr 30, 2005 | 08:50 AM
HarvesterUT's Avatar
HarvesterUT
Michla22......where around Austin were those pics taken? that road looks really fun.
Old Apr 30, 2005 | 11:02 AM
need Z's Avatar
need Z
*waits patiently for the how-to*
Old Apr 30, 2005 | 12:55 PM
Michla22's Avatar
Michla22
I used a sink hole cover to cover the hole here's a link to a write up on another site:
Well they won't let me link it , check searches for removing the rear wiper on this forum and others for some other writeups.
This road is realy fun - it's little arkansas road - it goes in between wimderley and san marcos. It's a very back back road - i had to hit a low water crossing with a bit of water to get to it. But there is no traffic on this road , i was on it for about 2 hours taking pics and not one single car
Anyways here's a quick how to:
remove the plastic cover on the base of the wiper (it just pops off)
There should be a nut under that on a post. Remove the nut. Then the wipe is mashed down onto the metal post so you're going to have to swist and pull a bit to get the wiper off - this won't be easy. I twisted mine until it came off.
then remove the plastic lining on the back hatch
The wiper motor will be located here - i circled the bolt holes - unplug and remove the motor
motor:
This will leave you with this hole:
I then painted the sink hole cover gloss black and then added silicone to the bottom of it to seal water out. Wait for paint to dry and press it over the hole. the silicone should dry in about a day. I put it on over night and then left it to sit in the sun the next day and the cap settle down all the way to the body very nicely. And that's that. - buy some rain-x
Hope that helps. Once again click on pics for larger view.
Old Apr 30, 2005 | 01:47 PM
sentry65's Avatar
sentry65
the burninator
how much does the wiper and motor weigh? 5 lbs?
also how much does that plastic on the hatch weigh? weigh nothing pretty much?
I generally keep my car clean enough to not need the rear wiper....
i kinda like how the hatch looks without the plastic
Old Apr 30, 2005 | 04:23 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Yea, you really don't need it since the only time you can really see it is when it's open. If you're thinking weight removal it can't weigh more than like...2 lbs. or so.
Old Apr 30, 2005 | 04:30 PM
2003z's Avatar
2003z
Like Z-INCOGNITO said, welcome to the club!
Old Apr 30, 2005 | 04:55 PM
thunder0880's Avatar
thunder0880
its looks clean, but i use mine sometimes when it rains. If i didnt though it would be coming off.
Old Apr 30, 2005 | 10:28 PM
Acree's Avatar
Acree
looks clean, very nice job man. Welcome to the club. Take it a step further, get it painted and put one up where the fluid nozzle is.
Attached Thumbnails Removed Rear Windshield Wiper-img_1157.jpg   Removed Rear Windshield Wiper-img_1161.jpg
Old May 1, 2005 | 03:53 AM
Michla22's Avatar
Michla22
The wiper motor only ways a couple pounds.
Thx I'm enjoying the club, however i'm not sure what to use to cover the fluid nozzle hole. I was thinking of rerouting the water line back to the front though - eventually use it to spray on an intercooler when i get the $ for turbos. For now it will become a water gun
Old May 1, 2005 | 06:23 AM
Santacruzslick
Veteran
My friend turned one of his sideways to spray people as he goes by. Hilariously funny! Make yours spray directly back so if someone is tailgating you can spray them.
Old May 1, 2005 | 07:18 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Looks good! I've been meaning to do this for a while now. I just need to get matching paint for the cover. I know there's like a 5-10 lb weight in the hatch (I think).
Old May 1, 2005 | 07:36 AM
2003z's Avatar
2003z
I removed my nozzle and put my sirius antenna there.
Old May 1, 2005 | 10:37 AM
Roger V's Avatar
Roger V
Do you have pictures of this?
Old May 1, 2005 | 11:16 AM
Santacruzslick
Veteran
+1...wouldn't help me since I have a roadster but still interested.
