4 point harness install
Old Jul 2, 2005 | 09:56 AM
zownz's Avatar
zownz
Default 4 point harness install
has anyone installed one on their Z, or anybody can give me a guide on how to install them
Old Jul 2, 2005 | 03:10 PM
konspec's Avatar
konspec
either install it to a harness bar, roll cage, or don't bother. Those are the only safe methods I've heard of. If the harness is mounted below your shoulders then it could compress your spine on impact(bad)
Old Jul 2, 2005 | 03:18 PM
Chebosto's Avatar
Chebosto
typically u should use like a 4 inch square steel plate with an eye bolt in the center, weld the steel plate to the frame, and then attach the belts to the eye bolt. Konspec is right, dont do it unless you plan on using a roll bar-
might i suggest:
http://www.cg-lock.com/
for your driving needs.
Old Jul 2, 2005 | 05:05 PM
Reggi914's Avatar
Reggi914
might i suggest:
i wonder if insurance companies can hold this against you if you were in an accident and got hurt.
HoBrahYouStink
Jun 24, 2016 10:58 PM
