seibon hood HELP!!!!!!!!
Old Jul 11, 2005 | 08:49 AM
denic79's Avatar
denic79
Default seibon hood HELP!!!!!!!!
Just got my seibon oem hood. I had a hard time lineing it up and it's still tight near the drivers headlight and on the drivers side along the fender there's a little gap on the passengers side is perfect. Should I send it back and get another one. Also do I have to drill holes on the underside to install the rubber seal in the front. Also the bumpstops won't fit. The holes are to small. Did anyone have these problems.
Old Jul 11, 2005 | 08:50 AM
denic79's Avatar
denic79
I will take pictures too so you guys can give me some ideas.
Old Jul 11, 2005 | 11:07 AM
LaidbackRacr's Avatar
LaidbackRacr
Pics would greatly help
Old Jul 11, 2005 | 11:49 AM
Tantrum Z33's Avatar
Tantrum Z33
You will have to play around with the 4 screws and the latch to line up the hood right. You will need to drill the holes bigger in order for the weathering strips to fit. Did you buy this locally?(Hope you did because Seibon will most likely not take the hood back) I went through 2 months trying to return my defective hood to find out that Seibon was just wasting my time with no intentions of giving me a refund or a exchange. Good luck with your hood.
Old Jul 11, 2005 | 12:42 PM
denic79's Avatar
denic79
I bought the hood from Jeff at 500whp.com..... I figured I had to drill holes for the weatherstripping and longate the holes for the rubber stoppers. The hood didn't even come with any hardware to bolt it in. Do I need to install the weatherstripping right away or can I wait? I'm going to go take some pictures in a little while so you guys can see what I'm up against. Thanks for all the help.
Old Jul 11, 2005 | 12:56 PM
denic79's Avatar
denic79
Here are the pictures.....
Attached Thumbnails seibon hood HELP!!!!!!!!-dsc00227.jpg   seibon hood HELP!!!!!!!!-dsc00228.jpg   seibon hood HELP!!!!!!!!-dsc00229.jpg   seibon hood HELP!!!!!!!!-dsc00230.jpg   seibon hood HELP!!!!!!!!-dsc00231.jpg
Old Jul 11, 2005 | 01:26 PM
teh215's Avatar
teh215
Looks like the drivers side hinge mount needs to move a little toward the front of the car... My 2¢
Old Jul 12, 2005 | 12:15 PM
funkdamonkman's Avatar
funkdamonkman
Looks like it will fit better than mine. My TS hood seems to be too narrow (gaps on both sides).
I agree with teh215. Move the driver's side toward the front of the car.
Does your hood latch correctly?
:edit: I just noticed that the front driver's side is too close to the light to move it up... um... I don't know what to say then.
Old Jul 13, 2005 | 03:04 PM
taurran's Avatar
taurran
Did you get that TS hood recently? I was considering getting one, but I heard they had fittment issues with the TS. Some folks were saying that they may have fixed the fitment issues in later runs, but if you got yours recently that leads me to believe otherwise...
Old Jul 13, 2005 | 03:18 PM
ProfessorKan's Avatar
ProfessorKan
Ok this is what you do.
Pop the hood open, but dont lift it up all the way. Let the hood rest on the latch but not 'locked'.
loosen all 4 bolts, but dont unscrew any of them. pull the hood a bit on X & Y axis an make sure the hood lines up. if at this point the hood doesn't line up, then you have a defect.
see how that goes
Old Jul 13, 2005 | 03:25 PM
ProfessorKan
all hoods and bodykits are alike. the best fitting hoods / bodykits are the first patch.
a brand new molded hood can run about 200 patches without shifting too much.
ALL hood and bodykits are made from fiberglass. Over time the mold WILL shrink. Residue, wax, resin, heat, etc. etc.
Real carbon fiber is dry CF only.
90% of import cf parts are casted cf. i.e. Veilside V1 lip, CF hoods etc.
cf hoods work like this (in layers)
top
top clear coat / resin
1 sheet of thin cf
fiber glass reinforcement.
fiber glass structure
end
Contrary to popular belief, CF plays no part but for eye candy.
It's actually 1 sheet of cf on fiberglass backing. Thats why it's so cheap.
Dry carbon is REAL carbon fiber.
Old Jul 13, 2005 | 03:35 PM
taurran's Avatar
taurran
top
1 sheet of thin cf
end
I'm aware of this. Hell, I'd rather have a painted hood any day of the week... I just want to get a hood with some vents to allow for some airflow in the engine bay. The only option I have there is to go with the veilside fiberglass hood, which will cost me an arm and a leg to buy and get painted. Next option is to just buy a wet cf vented hood.
To the op: who did you buy the hood through? I know Seibon probably won't help at all but maybe the vendor will be willing to assist.
Old Jul 14, 2005 | 07:13 AM
ProfessorKan
Safety concerns are actually a factor. Rule of thumb when using any fiberglass / wet carbon hood, always purchase with a set of hood pins. Doesn't have to be SPARCO, any latch type pins which are bolted to the frame of the car.
3 mph frontal crash will destroy any hood, causing the fiberglass to split into pieces.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
Wu-Watt
East Canada
Sep 12, 2015 07:31 AM
