rear turn signal lights / EU-model /
Old Jul 15, 2005 | 09:08 AM
350zde's Avatar
350zde
Default rear turn signal lights / EU-model /
hi,
I'm driving an EU-model of the 350z. This model has the ugly red part of the signal light which I would like to change into the clear one of the US-model.
Now I would like to know if there is anything installed for using it as rear light like on the right side or isn't there installed any electric for this.
Also I need to know if there are stamped any signs and/or numbers on the outside of the white rear light. If there are stamped some, please let me now them.
Thanks,
with best regards from good old Germany
EU-Model:
J/US -Model:
Old Jul 15, 2005 | 09:33 AM
MustGoFastR's Avatar
MustGoFastR
Interesting. It's only like that on one side? In the US, that red section is another white reverse light, as on the opposite side.
There are some stamped items on it (can't look right now), DOT cert. and such.
Old Jul 15, 2005 | 09:40 AM
stopgo's Avatar
stopgo
Is that red portion your fog light? And if so, what sort of penalties would you be facing by changing it to a clear light?
Old Jul 15, 2005 | 10:09 AM
neur0sis's Avatar
neur0sis
Yeah, I thought it was mandated for EU vehicles to have a rear fog light?
Old Jul 15, 2005 | 11:01 AM
350zde's Avatar
350zde
Yeah, the red part is the fog light, on the right side we have the clear backlight for reverse.
We MUST have a red fog light here in germany, so when i use the clear one from your US-model i must use a red bulb in it, i have found some on http://www.minitrailers.com/Bulbs.htm
It´s crazy, in germany there is not only one red bulb with necessary approval....
Old Jul 15, 2005 | 11:05 AM
stopgo's Avatar
stopgo
Ohhh... I think I understand. Do you wish to change the lens to a clear one, and then install a red bulb?
That's a pretty elegant solution.
Old Jul 15, 2005 | 11:06 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
So can someone enlighten me as to how this rear foglight works? When does it come on? Is it manually switched on like all other foglights? Is it really a foglight or a brighter additional brake light? TIA.
Old Jul 15, 2005 | 11:09 AM
350zde's Avatar
350zde
correct ! I must change the complete housing, i get them for about 100 bucks
Can anybody tell me the numbers and signs on it, please !?
Old Jul 15, 2005 | 11:15 AM
350zde's Avatar
350zde
You must manually turn it on and it is a realy bright foglight. It is only allowed to turn it on when you can see less than 50 meters due to heavy fog.
Old Jul 15, 2005 | 01:57 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Well, it could be done but you would have to run your own wiring as that light(inside portion) serves as our back up light. You would have to install a switch and run wiring to the bulb.
Old Jul 15, 2005 | 02:14 PM
old_s13's Avatar
old_s13
EU lamps are next to near identical to the full clear US-spec lamps.
We are currently working on a EU-spec rear signal/fog assembly for a customer and the lens markings are the same: DOT / SAE compliant.
The difference between the internals of the lamp is that the EU-spec unit has a red filter lens responsible for the fog function. In addition, it also has the necessary metal shielding so that the housing does not overheat and melt.
Wiring harness is just about identical with minor change in the pin location of where the signal (or fog) pin is located. Easy to change though.
We'll be adding the EU-spec signals to our site in the next couple weeks, in addition to various other new creations that we've been working on. The new G35-coupe black housing / full LED tail lights are expected to be released next week as well.
Hope the info was helpful,
- Mike / ClearCorners.Com
Old Jul 15, 2005 | 08:49 PM
ares's Avatar
ares
Veteran
hey interesting fact. that 3rd switch next to the heated seats? thats for that foglight who knew! besides europeans...
I had made 1 UK fella a red LED bulb for it; wasnt certified but it worked well for him according to him. and it was clear when it was off so it had a nice clean look.
but if that even appealed to you; Im just teasing you cause I dont have the parts to make anymore .
Old Jul 15, 2005 | 08:54 PM
Santacruzslick
Veteran
Well you can buy parts...
Old Jul 15, 2005 | 09:12 PM
ares's Avatar
ares
Veteran
hah; wish I could; their out of production.
but I found a funky lookin UK science store that has something strangly similair... now if I can find my wallet I have a purchase to make.
Old Jul 18, 2005 | 09:05 AM
testaccount's Avatar
testaccount
I have taken pix from the foglight, so you can see:
(I am also 350zde, i have still trouble with my accounts....)
Old Jul 18, 2005 | 10:18 AM
Santacruzslick
Veteran
Oooohhh...so you have an extra switch on your blinker thingy.
Old Jul 18, 2005 | 10:23 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Nice! Thanks for sharing .
Old Jul 18, 2005 | 04:38 PM
bcheng4jc's Avatar
bcheng4jc
hey 350zde, couldnt take a good picture of the markings so i drew one out for you. my lens looks something like this.....is this what you were looking for?
Old Jul 18, 2005 | 06:10 PM
ares's Avatar
ares
Veteran
someone told me there was a switch between the seats with the hazard light and seat warmers. guess I was misinformed.
Old Jul 18, 2005 | 11:17 PM
old_s13's Avatar
old_s13
"hey 350zde, couldnt take a good picture of the markings so i drew one out for you. my lens looks something like this.....is this what you were looking for? "
writing is identical on US and EU models...
