did some painting today, engine dress up
Old Jul 26, 2005 | 03:28 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Default did some painting today, engine dress up
hope this is the correct forum.
I wanted to spruce up the engine bay and had seen other people paint their covers, so i did the same. original eh
full view
Engine cover close up, masking the letters was a pita but worth it
Battery cover and painted hood strut
Hood strut close up
Brake fluid cover
Very close shot of 3.5 V6, already can see a blemish
some of the pics look orangish (even the body panel in the 3rd!)but thats not how it is in person. The fifth pic is closet to the true color.
Can i paint the plenum with a high temp black paint? itd look so much better!
Old Jul 26, 2005 | 03:29 PM
B-Unit's Avatar
B-Unit
you didnt sand enough, did u even spray primer?? also looks like you could have used different brand primer, paint, and it looks like you didnt clear coat it either.
Old Jul 26, 2005 | 03:32 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
no primer,no sanding. the can said i didnt need to!!!!!!!
thinking about clear coating it, any suggestions?
Old Jul 26, 2005 | 03:44 PM
B-Unit's Avatar
B-Unit
well first off, if ur gonna clear coat it, just sand them down and restart it. Take like 320 and sand the crap outa it. then spray a plastics primer on it. Then sand with 400. Spray your spraypaint a couple a time, like 3 layer letting it dry between coats, then wetsand with 600, then once again with one more layer of color. Let that dry for like a day, then apply a a coat of clear coat, let it dry, then do 2 wetcoats. WetSand it down with 800, then get a rubbing/polishing compound and buff it. Then wax it if u like, itll shine real glossy. I recommend getting duplicolor for the primer, color and clear, itll make sure you dont get any funky reactions with the paints. sometimes when u mix brands of paint u get wierd *** results. GL
-B-
Old Jul 26, 2005 | 03:53 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
I've been wanting to put hood struts on. What kind do you have and how easy were they to put on?
Old Jul 26, 2005 | 04:07 PM
Rocks Wit VoX's Avatar
Rocks Wit VoX
looks aight imo
Old Jul 26, 2005 | 04:10 PM
GWAPITO69's Avatar
GWAPITO69
nice job but need to sand it, primer it, base coat then clear coat it.
Old Jul 26, 2005 | 04:26 PM
B-Unit's Avatar
B-Unit
LOL, sanding it ,primering, and clearing it would make it a nice job, right now, it is not a nice job LOL.
No offense to the original poster. it takes practice.
Old Jul 26, 2005 | 04:28 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
santacruzlick, the struts i have are off of ebay. A guy had tried selling the set 100 bin with n/r and 40$ start bid once. I spotted them a second time and bought them for 55 shipped. The were black originally. The ball ends were rusting so i decided to sand them down and paint em. The struts are 40lb each. The auciton included the brackets.
as far as installation, very very easy and is made much easier if you have a powerful drill and the chuck key handy (6v's of power and a hand tight chuck that makes the bit lock makes the job take longer) You should be able to install the struts in 30 min, but you have to modify the cowl which can take time.
Old Jul 26, 2005 | 04:32 PM
GWAPITO69's Avatar
GWAPITO69
oh yeah try spraying some adhesive promoter.before you prime it
Old Jul 26, 2005 | 04:34 PM
B-Unit's Avatar
B-Unit
nah, u dont need adhesion promotor if you sand it, adhesion promoter is good for slick surfaces like metal etc. just sand with 320
Old Jul 26, 2005 | 04:37 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
thing is that i like it, all that matters
and no i dont want a super glossy finish
Old Jul 26, 2005 | 04:39 PM
B-Unit's Avatar
B-Unit
yeah, whether or not YOU like it is the ultimate goal. Im just trying to give some advice for what MOST people look for with those engine cover paint jobs.
Old Jul 26, 2005 | 04:44 PM
LaidbackRacr's Avatar
LaidbackRacr
Mine looked a lot like yours, and if you used plasti paint you can actually sand after and primer not needed, I clear coated mine and they look flawless I will post pics after paint cures.
Old Jul 26, 2005 | 05:55 PM
taurran's Avatar
taurran
Can't view the pics from work. Maybe the host notworksafe.com has something to do with it.
Old Jul 26, 2005 | 06:06 PM
DavesZ#3's Avatar
DavesZ#3
Get some Bulldog Primer at any auto parts store. It sticks to plastics to paint will stick to it.
Old Jul 26, 2005 | 07:15 PM
TiPIACE's Avatar
TiPIACE
that looks really good. I wouldnt sand and start from scratch just yet. Give them a soap wash, 2 coats of clear and see how it comes up. If ur happy, then you've saved urself a **** load of time
im painting my brake/battery covers gloss black atm, and had a bit of trouble getting the paint to stick even using a primer. I tried some adhesion promoter and its looking good now, but takes a fair bit of time to get complete coverage over those little holes
nice job on the struts install, i like how youve put the rubber capping on the cut line, very clean. Im thinking about painting that area gloss back too now, you've created more work for me
Old Jul 27, 2005 | 05:16 AM
PumpedVA's Avatar
PumpedVA
What Hood strut is that?
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Cashwin
Oct 1, 2015 06:36 AM
