Where can I buy headlights?
If you need the OEMs, Performance Nissan has them. Aftermarket, would be ClearCorners.com . As far as I know, they're the only one selling aftermarkets right now unless you know someone that can do it for you or if you know where to get the K-Style headlights.
Originally Posted by ///M350Z
thanks
if you need to replace your headlights because they are broken then you will have to pay over $700 a piece from any store basically.
If you have a base model and you want to upgrade to HID I can get you a set.
Buy a pair of Philips 5000K HID bulbs off ebay - $75
Find a set of Hella (preferred) or Bosch Ballasts with ignitors, like these for $270
http://cgi.ebay.com/ebaymotors/Xenon...89632294QQrdZ1
Cut the mounting ring off a set of H7 (if you own the base) and JB weld it to the HID bulbs. Dremmel a bit of the HID plastic where you need to so that the bulb fits into the stock bulb location.
Find a place to mount the ballasts, wire them in (do a search for some how to's), seal everything back up, and you're done. And it only cost you $350.
