Nismo Shift knobs?
Old Aug 1, 2005 | 09:47 AM
mista350z's Avatar
mista350z
Default Nismo Shift *****?
I am looking to replace my stock shift **** cause it is pretty worn out in 3 days. the dealer said they would do it for free. I am comtemplating which Nismo to go with....I have seen all the pics in forum of what they look like on the car. I like the Nismo Titanium but am very concerned about the heat factor. Is it as bad as what everyone says. I if it is, I am looking at the black rubber GT or just replacing with a new stock one. Any ideas of which one I should go with?....Thanks in advance for your input.
Old Aug 1, 2005 | 09:52 AM
yobri's Avatar
yobri
Heat is a factor for virtually any **** when left in direct sunlight. This goes for the stock leather one or a Nismo titanium one, although the severities will be somewhat different. You can always cover your **** when parking in direct sunlight, or get one of those sun shades to protect from heat entering directly into your car (on to the shift **** area). The black rubber GT is also a nice selection, but I'd still advise the same protection when parked where direct sunlight will be on the **** itself.
Old Aug 1, 2005 | 10:04 AM
GZire's Avatar
GZire
I had the Nismo Titanium GT on my car for a while. I'm using Clint's SS **** now.
Yes the heat is going to be there if it's in the sun, but it really hasn't bothered me too much. The plate of the top of the stock **** is definitely way worse than the Nismo or Clint's ****.
If heat is an issue, I'd go with a leather wrapped **** or the Nismo rubber ****.
Old Aug 1, 2005 | 10:07 AM
SOCAL350's Avatar
SOCAL350
I have a UTR Ti **** and it gets just as hot as any chrome **** ive had in the past. Buy a rubber **** or dont forget your hat would be my suggestion. Got to love that So Cal sun shine.
Old Aug 1, 2005 | 10:16 AM
Art Vandaleigh's Avatar
Art Vandaleigh
I have the Nismo TI **** and love it. Shift feel is much improved over stock, and it looks a hell of a lot nicer. Heat is a hassle tho, in 85+ weather this thing will burn your hand but just put a hat over the top and problem solved.
Old Aug 1, 2005 | 12:21 PM
VQ35DECivic's Avatar
VQ35DECivic
I have the Nismo nub **** (the super-small one) in black. I was introduced to it by a friend who uses it in his GT-R, so I figured if it's good enough for a 500hp Skyline, it's good enough for my lowly 300hp Z.
It's plastic in construction, has absolutely no metal on it to burn my hands on a hot SoCal day, and is the most cost-friendly Nismo shift **** there is.
Performance Nissan has it for $37.
Other than the fact that it's about the only one that doesn't burn your hands, it also supports a variety of shifter-grip styles. You can hold it from the top, the side, pistol-grip it, use a couple of fingers, use the flared bottom as a handle, ring it with your fingers, thread it through your fingers... you'll FIND new ways to shift w/ it! I love it, and it even goes all the way down to the OE shift boot in the Z, so that there's no silly "aftermarket-shift-**** boot/**** gap."
Old Aug 5, 2005 | 09:19 AM
ryanmac516's Avatar
ryanmac516
i like boobies
i had the chrome and the gt titanium shift **** chrome got hotter the the titanimu and i like the feel of the gt **** better than the tall thin chrome ****
Old Aug 5, 2005 | 09:52 AM
Miraclekidjr's Avatar
Miraclekidjr
nismo key
I like that
Old Aug 5, 2005 | 09:53 AM
yobri's Avatar
yobri
This is EXACTLY the same situation for me as well
Old Aug 5, 2005 | 07:45 PM
05-Z's Avatar
05-Z
try voodoo....my favorite. cheap, and they fit perfect.
see the redline shiftbott thread!
Old Jan 7, 2009 | 03:07 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Anyone have pics of the NISMO ball shifter installed?
Old Jan 7, 2009 | 05:15 PM
bigbgballz's Avatar
bigbgballz
Default Tomei
Try Tomei. Its made of Duracon and it does not get very hot. It is comfotable also.Check the shift **** thread for more choices and reviews+pictures on Nismo and other brands if you have not done that yet.
Old Jan 7, 2009 | 06:36 PM
geomark's Avatar
geomark
Originally Posted by yobri
cover your ****
Definetely good advice
Old Jan 8, 2009 | 09:50 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
http://mynismo.com/categories/?id=2331
Old Jan 8, 2009 | 11:36 AM
Spork's Avatar
Spork
I have the Nismo black aluminum one. If left in the direct sun, it does get pretty hot. Nothing unbearable tho.
Old Jan 8, 2009 | 12:50 PM
Done Deal DR's Avatar
Done Deal DR
I have the Nismo Black Resin one. Its an extremely small ****, a lot smaller than I expected. I didn't even put it on for probably 8 months after I got it because I thought it would look stupid. Finally put it on and it looks and feels pretty good, and doesn't get hot.
That said, it's a little TOO small for my liking and I think I will switch to the TK or ARC **** and just deal with the AZ heat. I used to be a firefighter so I'm used to being burnt.
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
