repainting brembos
Old Aug 17, 2005 | 12:55 PM
Tackett's Avatar
Tackett
Default repainting brembos
did a search for this and came up empty, so Ill just go ahead and ask.
If I want to repaint my brembos, I am assuming I will need to strip the existing paint off of them. Any good products to do this with? Or should I just use regular 'ole paint stripper, sandpaper and elbow grease?
I also found the brembo stencils online also, so if anyone was looking here you go.
http://shop.store.yahoo.com/eagleday/brcapaki.html
Thanks
Old Aug 17, 2005 | 01:57 PM
captj3's Avatar
captj3
You are going to need high temp paint reg paint will peel off from the heat.There is someone on motoring or frenzy his name is 2003z he powder coats them he's reasonable and does a good job.I've seen his work.
Old Aug 17, 2005 | 02:00 PM
bixby's Avatar
bixby
Unless they're flaking stripping is not required. Use G2 caliper paint available at www.tirereack.com. It goes on with a brush & dries like glass. You don't even neet to remove the calipers.
Old Aug 17, 2005 | 03:14 PM
BJF2K's Avatar
BJF2K
Here's few pix of what my friend's shop did for their customer
they are direct distributor for brembo USA (RT)
www.lucentmotor.com
Old Aug 17, 2005 | 03:26 PM
2003z's Avatar
2003z
Best way to strip them is with kleen-strip heavy duty stripper from home depot, then finish up with a dremel and wire brush attachments.
and here are some that I powdercoated in my shop.
Attached Thumbnails repainting brembos-z-pics-020-medium-small-.jpg   repainting brembos-black-brembo-001-custom-.jpg
Old Aug 17, 2005 | 03:27 PM
2003z's Avatar
2003z
btw, those eagle day stencils are too big for the rear brembo. you will only be able to do the brembo logo on the rears, like in the black brakes above. I have since sourced a different stencil supplier that makes them in the correct sizes.
Old Aug 17, 2005 | 04:46 PM
BJF2K's Avatar
BJF2K
Here's few more
Old Aug 17, 2005 | 05:45 PM
westpak's Avatar
westpak
SFZCC
Here are mine done by 2003Z
Old Aug 18, 2005 | 04:22 AM
Tackett's Avatar
Tackett
Wow those look really nice man. I want mine exactly like that, but yellow with black lettering. If I had a simple way of letting you do mine without having to drive to atlanta or ship the calipers in the mail, Id love to let you do it. However, as it stands, I hate where I live, its impossible to get anything done like this. When I go to a body shop and ask them to do it, they just kind of give me a blank stare. So, alas, I will have to do it myself. If you could hook me up with some of those correct sized stencils, I would really appreciate it. Just give me a price and Ill mail you a money order if you would like.
Thanks for all the help.
Old Aug 21, 2005 | 04:56 AM
Tackett's Avatar
Tackett
Oh yea, forgot to ask. Will I have to bleed these things and take them off, or can I just remove them from the rotor and paint them? I hate bleeding brakes. hate it.
Old Aug 27, 2005 | 12:08 PM
westpak's Avatar
westpak
SFZCC
If you are going to just paint them most people mask off the area around the calipers and paint them installed.
Old Aug 27, 2005 | 03:56 PM
TxTitan's Avatar
TxTitan
www.lucentmotor.com
Dam nice work your friend does.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
