How come so many don't shine their tires when taking a pic?
Thanks, well aware of that, that is why I put the tire shine when light out so I can see that it only goes on the side.
Originally Posted by rich150001
I used this for the first time yesterday and was impressed by the shine it gives but be careful. I was making a quick turn and my rear slid out from me and I came really close to hitting a curb. I looked at my tires and the tire shine had gotten to the bottom of the tires.
Yeah, I don't use the sponge that comes attached to it, you can't control the spread. I ususally snap off that sponge and use it just as a gel. I take another tire sponge and apply the gel on the sponge so I can control exactly the amount of gel I put on. I suggest you do the same if you want to have total control of the spread. I only use black magic because that is the only gel at my store. everything else is spray and foam.
Mine was only on the side of the tires but I think I may have put too much and it dripped onto the bottom of the tires while driving...I never had that problem with armor all tire spray.
I just use original armorall on a terry cloth to wipe them down and clean the gunk off. It doesn't actually shine them, it gives them a smooth, clean look.
http://www.350zclubofflorida.com/php....php?user_id=3
I tire shine my tires every time I wash my car, but the sponge applicator is definitely the best way to go. And after you start shining them they always do have to be shined or they look crappy,
Originally Posted by jmerickson
to prevent from getting the stuff spraying all over the side of your car i use the foam paint brushes to apply tire shine to the tires. and let the car sit for a little while before i drive off again.
This is the way to do it, IMO. I buy the 2inch ones at Walmart for $0.20 each. I've been using the meguire's spray as opposed to the spray can. Just spray a little on the brush and paint away. I usually let it dry then do 1 more round if it's not to my liking. I think its better than the eagle applicator because you can just toss'em out when you're done.
First step is to brush/clean the tar/dirt off the tires or the shine won't last that long no matter what you use...
etkms
Jun 19, 2022 06:30 PM
