GTFactory Diablo Door Installation Procedure
Old Sep 29, 2005 | 04:46 PM
  #61
usmanasif's Avatar
usmanasif
Looks good, man. Once you drive it out on the highway, post on whether the seal is still OEM-tight. I'll be looking into this when i get my Z.
Old Oct 1, 2005 | 02:58 PM
  #62
VertexFightR's Avatar
VertexFightR
Sorry, the bumpers, sideskirts, fenders, and door panels are only partially installed in order to take some pictures for you guys...namely Toby. Before I put the fenders back on, I forgot to take pics of the filled/sanded welded areas, so those will be Monday or Tuesday when the car is fully completed.
The last picture kinda shows the clearance by the fender and A-pillar. This clearance is the main problem people have...they can't get the door or door panel to fully clear the fender or A-pillar. Needless to say, this car clears both.
I've got a shop full of cars with lambo doors, the orange Z is the latest in line, to be done right after Toby's is sent on it's way. I will tell you though, when people come in here, they're like they have blinders on....they seem to be only interested in the 90 degree GTFactory doors.....
Old Oct 2, 2005 | 07:50 AM
  #63
kcobean's Avatar
kcobean
Looks amazing Steve. I know that this has been a frustrating wait for Toby, but I'm sure the final product will make it all worthwhile. Nice work.
Old Oct 2, 2005 | 10:44 AM
  #64
PumpedVA's Avatar
PumpedVA
got to love that!!! also who is getting what done to that orange Z?
Old Oct 2, 2005 | 11:22 PM
  #65
Dragonstyle's Avatar
Dragonstyle
wow...what a crazy install....
Old Oct 2, 2005 | 11:44 PM
  #66
usmanasif's Avatar
usmanasif
BTW, are those random plates? Looks like it. JDM! What luck!
Old Oct 3, 2005 | 12:14 AM
  #67
Acree's Avatar
Acree
that's just freakin sick. i must say this guy is probably one of the most devoted technicians i've ever read about. that's just crazy man! nice car.
Old Oct 3, 2005 | 10:26 AM
  #68
gatti-man's Avatar
gatti-man
Very nice, i really dig the door panels. I plan on doing a yellow to white job on my car sooner or later.
Old Oct 3, 2005 | 10:45 AM
  #69
PumpedVA's Avatar
PumpedVA
kelly your right bro it has been frustrating (for both of us) but looking back on things I would have never trusted another shop to do this install. There are just WAY to many things that can or did go wrong but most shop would have just covered up
Old Oct 17, 2005 | 04:03 PM
  #70
VertexFightR
Default Finished doors
Doors in closed position
Doors in open position
Welds to inner frame and door were grinded, body filled, and painted to provide OEM look and finish
Fiberglass GTF panels
Tein Bonnet Dampers
Hood shocks don't fit with the OEM battery/driver side covers, or to be more specific the plastic frames that house those covers. The ends of the plastic frame had to be cut in order to allow clearance for the dampers in the closed position. You can see the rubber looming that covers the cut plastic edges in this picture.
I think these are JP Aero sideskirts. On all the cars I've seen them on, the rear portion doesn't sit flush with the quarter panel. I've seen the front not sit flush as well. The solution I've seen so far is some installers put double-sided tape on the inside of the skirt and try to stick it to the car. However, over time, the pressure of the sideskirt trying to pull away as well as particles of dirt that get caught on the edges of the tape eventually nullify the effect of the tape. The mounting angles in the front and rear of the skirt must be adjusted one end at a time, thus sit flush against the fender and quarter panel of the car without the need for tape.
Foglights off and on
The high swinging doors provide a huge opening for ease of in/egress
Old Oct 17, 2005 | 04:48 PM
  #71
Vamos_Rafael's Avatar
Vamos_Rafael
how long did the lambo modification take?
wow thats beautiful?
Old Oct 17, 2005 | 09:47 PM
  #72
usmanasif's Avatar
usmanasif
Nothing like truly vertical doors. Helluvan install! I wouldn't worry about the quality of the install if you were the one doing it. Props!
Old Oct 18, 2005 | 06:36 AM
  #73
mdracer76's Avatar
mdracer76
WOW! Great pictures
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
