Correct/Best method to Roll Fenders?
Old Nov 21, 2005 | 07:06 AM
mojo powered's Avatar
mojo powered
tirerack also used to rent fender rollers.. not sure if they still do though
Old Nov 21, 2005 | 09:38 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hector at F1Motorsports cut my fenders. He does a good job and was really quick.
Old Nov 21, 2005 | 11:39 AM
Zexy's Avatar
Zexy
Originally Posted by Jason@Performance
If they cut too much, the inner fender tub will come loose from the outter fender...
I had mine rolled and pulled...
Now you have me doubting cutting my fenders...
If the heat gun/fender roller works, shouldn't the ol' towel/baseball bar or mallet with heat gun work?
Old Nov 21, 2005 | 11:51 AM
002-M-P's Avatar
002-M-P
It does work, its just much "ghetto'er" and un-uniform.
Old Nov 21, 2005 | 01:19 PM
Zexy's Avatar
Zexy
Thanks guys, i have rented the fender rolling tool!
Old Nov 21, 2005 | 01:34 PM
aznmojo's Avatar
aznmojo
can someone post of a pic of fender cutting? Seems like a good alternative only if it doesn't end up all jagged.
Old Nov 21, 2005 | 01:38 PM
bmxox's Avatar
bmxox
I have a fender roller and heat gun for rent as well. PM for me details.
Its easy to do, anyone can do it. Just take your time, be patient and use the heat gun or your paint will crack.
Old Nov 21, 2005 | 03:20 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Make sure you use that heat gun....heat and patience are the most important things or else you WILL crack your paint.
Old Nov 21, 2005 | 03:38 PM
Zexy's Avatar
Zexy
Thanks Bri!! How long should the paint be heated? How should i apply the heat?
Old Nov 21, 2005 | 10:18 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Use the heat gun and keep it about 2-3 inches away from the paint. Keep moving it back and fourth in a 5-6 inch area until the paint is hot to the touch. Be careful that you don't melt the paint and make it bubble though (takes A LOT of heat to do that).
Old Nov 26, 2005 | 12:08 PM
Zexy's Avatar
Zexy
Alright guys. I have just rolled my fenders. Their is good news and bad news:
-Good news: Rolled them in all the way and managed to pull the fenders a bit for more clearance.(New wheels have very aggressive offset.)
-Bad news: I have used the heat gun and some paint did manage to crack. On the driver's side it is not too cracked. Only in one small part. In the passenger side their is a 6 inch wide crack on the fold. Gotta visit the body shop to fix this.
How much am i looking to spend to fix the chipped paint?
Old Nov 26, 2005 | 12:12 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
To "correctly" fix they'd have to strip and re-paint...which would cost well over $1000 at a good body shop. Just throw some touch-up paint on there and you should be just fine.
When you were rolling the fenders....did you go really slow and only do small sections at a time?
Old Nov 26, 2005 | 12:30 PM
Zexy's Avatar
Zexy
I would say i went a bit faster on the passenger side(30 mins) but the paint is just so extremely delicate.
$1000 is alot! When they hit my brother's fender he had a big chunk of paint chipped off and the fix was only $200! The job came out flawless as well. I'll have to go back to this shop.
Old Nov 26, 2005 | 12:54 PM
VIP-STATUS's Avatar
VIP-STATUS
We cut or roll fender here too.We do MBZ+BMW all the time.I cut my Z for max tire and wheels fit to fit.If it's more then 5mm you should cut it.HEAT UP then roll. for 3mm and less.
Old Nov 26, 2005 | 08:46 PM
350Zteve's Avatar
350Zteve
Status, how much do you charge for rolling the rear fenders of a Z?
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
