Finaly removed rear wiper assy.
Old Oct 9, 2005 | 07:41 AM
zYouLater's Avatar
zYouLater
Default Finaly removed rear wiper assy.
Finaly removed rear wiper assy. Wanted to do this since day one! Finaly found what I wanted to complete the removal. Just wanted to share this with you guys.
Steps:
1. remove plastic cap from base of wiper arm
2. remove nut off of wiper arm
3. gently pry up on wiper arm while releasing tension on front of arm
4. set aside all parts thus far
5. open hatch and gently pry on plastic hatch cover until you hear the plastic plugs pop free. pull gently until all are free and cover is away from hatch
6. wiper assy. will now be exposed. Remove three nuts holding assy.
7. cap off wiper hole with product of your choice?
8. Estimated time 20 to 30 mins
Old Oct 9, 2005 | 08:52 AM
LaoSiFu's Avatar
LaoSiFu
Always wonder, what are you guys using to cover the hole??? I really don't know where can I find it.
Old Oct 9, 2005 | 09:21 AM
Sexy350zStud03's Avatar
Sexy350zStud03
you should also remove the rear fluid nozzle and to cover the holes go to homedepot and go to the plumbing section and get a sink hole cover or go to the bolts and nuts section and get a hole cap. Paint both to match your car.
Old Oct 9, 2005 | 09:23 AM
zYouLater's Avatar
zYouLater
Thanks, attached a pic of yours, so I can see how yours looks.
A.P.
Old Oct 9, 2005 | 09:29 AM
Sexy350zStud03
i do not have any yet just finished it this weekend will post many pics probabaly next weekend
Old Oct 9, 2005 | 10:15 PM
PHARM Z's Avatar
PHARM Z
Question
Where did u get that carbon fiber insert? that thing is really sweet!
Old Oct 9, 2005 | 10:19 PM
Roger V's Avatar
Roger V
Are sink hole covers easily removable?
Old Oct 10, 2005 | 05:24 AM
MustGoFastR's Avatar
MustGoFastR
Yep, they have a threaded shaft and a plastic nut that holds it from underneath. I sealed mine with a small amount of aquarium silicone to ensure against leaks; it'll pull right off if I need it to.
Still haven't figured out how to get the damned rear washer nozzle of...
Old Oct 10, 2005 | 09:51 AM
tommykung's Avatar
tommykung
Code:
+1
Old Oct 10, 2005 | 09:57 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Will try this....Maybe this weekend
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
