Is it hard to match paint for PPW on bodykits?
Yes. It is pretty difficult to match the paint because the shades of the pearl on the white is hard to control. Take it to a good shop if you want a decent job done.
Mine came out pretty good...but I paid a bundle for it.
Pix
https://my350z.com/forum/media-share/148819-twins-no-not-that-twins-d.html
Pix
Pix
https://my350z.com/forum/showthread.php?t=148819
Pix
each color has several "variations", each very very close. a good shop can take your paint code and something like a splash guard or gas door and match perfectly. you can't just pull the paint code and go with it. i learned alot from having my body kit paited this week from the shop i used.
I have an LS as well and I took it to a very reputable shop and they still couldn't match it.
You can tell it's off, especially in the sun, where you can tell it's a different shade. And they did try to match it to the color of my car. So I'd have to say that with aftermarket it's hard to match, except if your car is black.
Nice rims Phatmitzu
Even on those pix I can tell the white on the skirts are a different shade. Doh.
You can tell it's off, especially in the sun, where you can tell it's a different shade. And they did try to match it to the color of my car. So I'd have to say that with aftermarket it's hard to match, except if your car is black.Nice rims Phatmitzu
Nice rims Phatmitzu
Even on those pix I can tell the white on the skirts are a different shade. Doh.WOW that sucks man. my body shop told me that LS had the fewest variations (3) and it was the easiest of the Z's colors to match. mine came out perfect, will post pics when i get her cleaned up.
my brother is a body man and painter. I can tell you that it all comes down to the skill of the painter. Certain brands of paint may be easier to match, but going with a certain brand paint does not garauntee a match.
White is usually the hardest paint to match. Most colors on the Z are difficult because of the amount of pearl in it. Just make sure you take your car to a reputable shop and tell them that they will need to repaint if you are unhappy with the color. Most good shops will do numerous test panels to match the paint before they paint the car, so they should be able to tell you before the car is painted how well they can match the paint.
My car is PPW and I was in a recent car accident. My car is at the bodyshop right now and I am having the same concerns as you. He said PPW is hard to match but nobody will match it perfectly. He says that paint turns out different on certain materials. Say metal and plastic (bumpers). It will be off slightly. If you look at your stock bumper vs your stock fender you can tell that the bumpers or anything that is plastic will be off slightly. Its more yellowish.
I just hope the bodyshop gets it as close as possible. Im getting the Vertex Half Lip kit and its on back order so the kit will have to be painted after my car is done. This also concerns me.
I had nightmares getting my front bumper to match after getting it repainted.
After 5+ weeks at the shop... they decided enough was enough and blended the paint. That's the only way to ensure a good match.
PPG is like mad expensive paint, thas what they use on the lambos etc.. .
i think it depends on whose mixing the paint, even with the color code from factory, the right mix is what it really depends on....the right % of color and pearl
