Some removal questioins
Old Nov 11, 2005 | 09:33 AM
XM 1's Avatar
Default Some removal questioins
hi everybody,
i´ve got some questions about "how to remove...".
i would say let´s start with the oem rear wing.how could i remove it and will
there be some holes in the hatch????
second is:how could i remove the rear wiper without take the whole wiper motor out???(i mean is it possible to get the axle of the motor out)is this possible at all????
best regards
Old Nov 11, 2005 | 11:14 AM
defex's Avatar
defex
bump on the wiper question. It's ugly.
Old Nov 11, 2005 | 11:59 AM
ANXIOUZ's Avatar
ANXIOUZ
If you remove the OEM wing you will have holes.
As for the rear wiper, do a search. Somebody here was able to remove it entirely.
Old Nov 11, 2005 | 12:06 PM
MustGoFastR's Avatar
MustGoFastR
The wiper motor assembly is very easy to remove; why would you just want to take the shaft off? I don't think that can be done.
Old Nov 11, 2005 | 12:34 PM
Daytona350Texas's Avatar
Daytona350Texas
ya you can leave the motor in there... but the whole cover has to be able to go thru a certain amount once covered and with the motor in there thats just added weight and wont do anything... taking it out is easy.
with hatch open pull back plastic panel its all rivits, then take a 10mm ratchet and take off the 3 bolts, then twist counter clockwise with motor in one hand and wiper blade in other, you have to twist HARD, it will finally break loose twist off and come right out... then find something like a sink whole filler and put it in there, seal it with a silicone of some kind and boom your done. Heres a link to kinda describe it a little better.
http://www.*3*50*z-Tech*.com/zwiki/T..._Wiper_Removal
Easy mod for amatuers and it looks SO much better!!!
EDIT:::: sorry forgot it wont let you post, just take the *'s away in link
Old Nov 11, 2005 | 10:54 PM
XM 1's Avatar
thanks for answers.
by the way i´m not a newbie i just wanted to know if there is a possibility to
do it another than remove the motor. but i think i´ll remove it
Old Dec 6, 2005 | 10:59 PM
thezedsled's Avatar
thezedsled
^---That link doesn't work...
Old Dec 7, 2005 | 12:08 AM
350Z_LMS's Avatar
350Z_LMS
Remove the * from the link and it will work! Nice site
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
