Clear Headlight Strips
Old Nov 13, 2005 | 09:43 AM
mahont's Avatar
mahont
Default Clear Headlight Strips
I am really interested in getting these but was doing some research on them and it seems a little crazy. Baking the headlights and a 4 hour install for them? I know its DIY so you are taking a small risk of ruining stuff if you screw up but how easy is this to do, it just seems like a lot of stuff for a little strip. Any feedback about the installation and how it went would be appreciated.
Old Nov 13, 2005 | 10:02 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Subscribing, I love the look but am afraid of ruining it.
Old Nov 13, 2005 | 10:50 AM
lgbdog1's Avatar
lgbdog1
+1. Don't have the *****. Don't even have the ***** to pay someone else to do it. I've needed 2 new sets of lights already from Nissan cuz of problems with them, and they wouldn't have been covered under warranty if I had done this mod. I'm just scared that something else will go wrong after I do this, and Nissan will tell me tough luck then. (I guess that'd be a good excuse to get '06 headlights though ;-)
Old Nov 13, 2005 | 12:34 PM
bmxox's Avatar
bmxox
Its not that hard, Ive done it to a few sets of lights. Ive never put them in the oven though, just used a heat gun, worked great. In the past I even used a hair drier, just took a little longer. Just take your time and you will be fine. In my opinion its definitly worth it. Builds your confidence a little bit too knowing that you did something like that.
I'll be pulling mine back out this weekend for 2 reasons. 1, they didnt seal all the way first time around and I'm getting some moisture, and 2, My smoked strips will be coming in. The first time I did it, I smoked the strip myself and the darkness is a little uneven when lit so I figured if im redoing them for the moisture, I might as well get the strip this time around. I also painted everything in there black. Maybe this time around I'll take some pics of the process if anyone has any questions.
Old Nov 13, 2005 | 05:10 PM
mahont's Avatar
mahont
I'm pretty sure on this site they had directions to install clear sidemarkers. I searched but couldn't find it. I'm installing those as well as considering the headlight strips so I'm looking for directions since the JDM directions came in Japanese.
Old Nov 13, 2005 | 05:18 PM
robbycolli's Avatar
robbycolli
subscribing for instructions when they are posted. Rob
Old Nov 13, 2005 | 05:19 PM
hndumafia's Avatar
hndumafia
i know this isn't apples to apples, but i opened my friends wrx headlights to take out the amber pieces and paint them black, and it took some time, but was overall really easy. i plan on eventually buying the clear strips and clearing my z headlights too.
Old Nov 13, 2005 | 05:20 PM
KTaylor's Avatar
KTaylor
haha rob yeah those did look good on that Z today i would like to see some instructions too.
Old Nov 13, 2005 | 05:22 PM
cessna's Avatar
cessna
There`s a sponsor (almost....) thats got anwsers to your questions....
Look up www.headlightarmour.com they have a good FAQ page...
Cheers,
Lou
Old Nov 13, 2005 | 05:25 PM
robbycolli's Avatar
robbycolli
i guess im busted. too much time on this site.
Old Nov 13, 2005 | 05:54 PM
bmxox's Avatar
bmxox
Heres a link to some directions.
http://ricks2k.com/info/instructions/350Z.pdf
Old Nov 13, 2005 | 06:11 PM
mahont's Avatar
mahont
Those are directions for the headlight strip. That is what this thread is about but I would also like to find directions on how to install the JDM clear sidemarkers.
Old Nov 13, 2005 | 06:22 PM
bmxox's Avatar
bmxox
To install the sidemarkers that are in the bumper do this....
Remove plastic shield under car, just a bunch of 10mm bolts. For the driver side reach up inside the bumper with a stubby phillips screw driver, remove the 2 screws holding the sidemarker in. Slide out the slidemarker and put the new one back in. For the passenger side you have to partially remove the bumper because the washer fluid bottle is directly behind the sidemarker.
The easiest way is to completely remove the bumper (follow instructions in link above) swap the sidemarkers and put the bumper back on. I can take my front bumper off in less than 5 minutes, the first time it may have taken me 10, its really easy and definitly makes it easier to swap the markers out. Hope that helped.
Old Nov 13, 2005 | 06:35 PM
KTaylor's Avatar
KTaylor
Thanks
Old Nov 22, 2005 | 07:58 PM
mahont's Avatar
mahont
Heat gun or oven? Which one is safer for this mod?
Old Dec 6, 2005 | 02:13 AM
blackznismo's Avatar
blackznismo
i did my headlights and worked on over 20 of them..piece of cake....if anyone in sacramento area i can do them for a small fee.....
Old Dec 6, 2005 | 05:12 AM
tuner4life's Avatar
tuner4life
here's the end result if u do the clear strip + flat black paint
Old Dec 6, 2005 | 05:55 AM
350ztoronto's Avatar
350ztoronto
anyone painted there headlight housing?? would like instructions to that
what year model did the headlights have problems?
Old Dec 6, 2005 | 06:13 AM
EriksonFL's Avatar
EriksonFL
https://my350z.com/forum/exterior-and-interior/152666-moisture-in-headlight-housing.html
Old Dec 6, 2005 | 08:27 AM
mgl's Avatar
mgl
i did mine with a heat gun. just take your time and everything should be fine. its not a hard mod, but just time consuming.
