Installed Seibon Hood...won't latch....help
Old Dec 6, 2005 | 11:51 AM
Barzten1's Avatar
Barzten1
Default Installed Seibon Hood...won't latch....help
Just got done putting on my Seibon hood but I can't get it to latch. Any help out there
Old Dec 6, 2005 | 12:13 PM
ZRAYGO's Avatar
ZRAYGO
You Have To Get Rid Of The Spring Under The Hood Latch. Thats Why I Got Rid Of Mine...also It Is Reccomended That You Get Hood Pins...
Old Dec 6, 2005 | 12:22 PM
Alberto's Avatar
Alberto
Cranky FI Owner
What kind of Seibon hood did you get? I didnt know the spring had to be removed to run these hoods, Ive never heard that, but good to know....
Old Dec 6, 2005 | 01:40 PM
Tantrum Z33's Avatar
Tantrum Z33
Becareful on putting too much pressure on the hood to try latching it. My friend did that with his Seibon hood and the cracks started to show up.
I never heard of taking out the spring on the latch to solve this problem either. Did you try lowering the latch by loosening the three bolts holding it in place?
Old Dec 6, 2005 | 03:09 PM
Barzten1's Avatar
Barzten1
No but thanks for letting me know how. Yeah, I have to slam the **** out of it to shut it
Old Dec 7, 2005 | 04:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Alberto
What kind of Seibon hood did you get? ..
+1 just curious....
Old Dec 7, 2005 | 05:02 AM
Nitrouz's Avatar
Nitrouz
Back to Z
just loosen the 3 screws on the latch itself, raise it as high as it will go (probably only a 1/4 of an inch), and screw the 3 screws back in tight. Then try closing it.
Old Dec 7, 2005 | 05:39 AM
Barzten1's Avatar
Barzten1
I got the Seibon TS hood.
Old Dec 7, 2005 | 05:52 AM
gringott's Avatar
gringott
I adjusted the latch on the car to make it fit. Like they say, loosen the bolts, and pull up. I did not remove springs. I do not have hood pins, I am thinking of putting them on as at high speeds I can see the hood vibrate quite a bit.
Old Dec 7, 2005 | 06:05 AM
Barzten1's Avatar
Barzten1
Do i have to take off the front bumper to adjust the latch?
Old Dec 7, 2005 | 08:08 AM
Nitrouz's Avatar
Nitrouz
Back to Z
no you don't. you have full access right there. Just look at the latch mechanism itself.
Old Jan 4, 2007 | 11:35 PM
Mazinger Z's Avatar
Mazinger Z
I have a Fiber Images hood...I adjusted the height of the latch to the very top. Still not latching. Any other ideas?
Old Jan 5, 2007 | 01:17 AM
just4AhoZZZ's Avatar
just4AhoZZZ
that should be all you need to do, just installed my seibon hood like a month ago, and all i had to do was just undo the 3 screws and lift it up, then tighten and close. ya and definately be careful about slamming it, i did it and cracks are there now. good luck with it all
Old Jan 5, 2007 | 02:47 AM
gringott's Avatar
gringott
Perhaps lower the part on the hood by using washers?
Old Jan 5, 2007 | 04:46 AM
davidf's Avatar
davidf
I removed the latch, 5 min. job. I use hood pins.
Old Jan 5, 2007 | 06:18 AM
THE TECH's Avatar
THE TECH
You may need to remove your strut bar in order for it to fit correctly. Anyone who says that these Seibon POS hoods fit like stock is lying.
Old Jan 25, 2009 | 08:43 PM
atomicgoofball's Avatar
atomicgoofball
i also am having a problem with my TS hood. I adjusted the latch When i first installed it...if i pushed down with enough pressure, The hood would shut and everything is fine.
this was months ago.
But recently i changed the battery, and when i try to shut the hood it will not latch anymore?? I checked the latch, its raised all the way up. I checked the hood and nothing looks out of the ordinary. It hooks the first hinge...but it will not latch all the way down to wear the tooth locks into the groove.
Any ideas?? why would this happen now all of a sudden? I didnt mess with the hood or anything, i just popped it like normal and now it will not shut
Old Jan 25, 2009 | 09:34 PM
Evilmexicaninus's Avatar
Evilmexicaninus
True True
Old Jan 26, 2009 | 07:16 AM
robbinsj's Avatar
robbinsj
Your having clearance issues after a battery change I would confirm that you replaced the battery cover correctly as it might be in the way. Next remove your strut tower bar. If it still does not fit then you need to check the underside of the hood for contact marks. Scuffs or scrapes where the hood is hitting somthing and if you need to confirm it was not there prior "on user hood" I use toothpaste on what I think is hitting then lower and see if it marked the underside. If no clearance issues then I would readjust your latch as it might of lowered when tightening and if that does not work then its time to remove the latch and run pure aerolock hood pins.
Old Jan 26, 2009 | 07:19 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
+2
