Full HID housing plug and play???
Old Dec 7, 2005 | 06:39 PM
showstoppertk's Avatar
showstoppertk
Default Full HID housing plug and play???
Hey guys...its about time I replace the crap-a$$ aftermarket HID setup that the previous owner had put on the Z and which also decided to crap out pretty quickly (I have a base Z). so, as I'm contemplating my options, I'm looking at possibly just picking up a whole housing replacement set out of a wrecked Z. they would of course include the entire housing, lens, projectors, ballasts and bulbs. now, if I get that, should I essentially be able to just unplug the aftermarket HID setup and plug in the new one? thanks.
Old Dec 7, 2005 | 06:47 PM
35oZephyR's Avatar
35oZephyR
Coming from installing HID's in my Base, to various retro-fit HID kits on other cars, I don't see why not.
The only snag or obstacle you would have is IF the harness/ connectors from the battery to the OEM ballasts were different. I don't see why they would be.
And even if It was different, it would be as simple as modifying the ends to have the black/ red wires connect. Ten cent job...fairly simple if you're swapping the headlights already.
Old Dec 7, 2005 | 07:14 PM
showstoppertk
hey 350zepher, how you doin? you comin back to hawaii soon? did you use the kit jun sells? I figure it should work, given those connectors are the same (as you mentioned). my current housings are a bit fogged (probably from the hole the previous owner made when he drilled into the cap on the back of the headlight housing) so if I can just buy a whole xenon headlight housing w/ the ballasts and bulbs for around $300, then why not? take it easy man
Old Dec 7, 2005 | 07:33 PM
35oZephyR's Avatar
35oZephyR
HAh, yeah I need to go back to Hawaii again when I get the funds.
I actually went with Brightstar instead of Jun's. Basically Plug-n-Play. I installed a McCulloh's kit on an S14b a couple days ago. The battery wires were a little too fat to go in the harness from the kit, so it was as simple as grinding it down with a dremel.
Our Z harness seems pretty universal. Shouldn't be a problem mating OEM with OEM on the same line of car.
Good luck and tell us how it goes.
Pleask
Dec 21, 2021 03:17 PM
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
