Over Head Console
Old Dec 23, 2005 | 07:17 AM
Lexquiles's Avatar
Lexquiles
Question Over Head Console
Hey all, I want to remove my over head console, I will be putting a TV in that space. I have no clue how to get the headliner off so I can remove the over head console, I could not find any screws or anything. I rather ask first before breaking something
Old Dec 23, 2005 | 07:42 AM
eTraxx's Avatar
eTraxx
Newbie
From the Shop manual. You can download both the 2003 and 2004 Shop Manuals in pdf from http://carfiche.com
2003
2004
REMOVAL
1. Remove back door welt. Refer to EI-46, "BACK DOOR" .
2. Remove luggage floor carpet. Refer to EI-39, "Removal and Installation (for Coupe Models)" .
3. Remove luggage finisher lower center. Refer to EI-39, "Removal and Installation (for Coupe Models)" .
4. Disconnect harness connector at luggage room lamp.
5. Remove luggage side finisher upper. Refer to EI-39, "Removal and Installation (for Coupe Models)" .
6. Remove kicking plate inner. Refer to EI-36, "KICKING PLATE" .
7. Remove body side welt. Refer to EI-35, "Removal and Installation (for Coupe Models)" .
8. Remove rear side finisher. Refer to EI-35, "REAR SIDE FINISHER" .
9. Remove seat belt anchor. Refer to SB-4, "Removal and Installation of Seat Belt (Coupe)" .
10. Remove rear pillar finisher. Refer to EI-35, "REAR PILLAR FINISHER" .
11. Remove front pillar garnish. Refer to EI-35, "Removal and Installation (for Coupe Models)" .
12. Disconnect harness connector at map lamp.
13. Remove sun visor and sun visor holder.
14. Remove dual lock fastener.
15. Remove clips of headlining rear potion.
16. Remove headlining, turn to 90 degrees and take out from back door.
CAUTION:
 Always remove or install in a pair.
 Cover surroundings with waste to avoid scratches or damages.
 Do not bend headlining too hard.
INSTALLATION
Install in the reverse order of removal.
Old Dec 23, 2005 | 07:45 AM
Lexquiles's Avatar
Lexquiles
Thanks!
Pleask
Dec 21, 2021 03:17 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
